I have a philips 50pf7321d plasma tv and the screen suddenly split, half picture on each side of screen, and black bar inthe middle.
  • 21 Answers
Black bar caused by a short IC on the ribbon of the plasma panel. Unfortunately it requires a new plasma panel. Cost of a new unit.
Posted on Apr 23, 2008
My Philips 50PF7321D/37 TV picture turns blue after about 30 secs of being on and I cant seem to get it to stop. Also when I turn the TV on it has a black screen with sound for about 15 secs before it
Unplug both the set and a box or receiver if used with the set, remove from power for several minutes and replug all to see if a reboot will help or not.
Dec 09, 2012 | Philips 50PF7321D 50 in. Plasma HDTV
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Picture comes on for split second
Hi.
Are you sure this is not on somthing like hide screen mode?
I am not responsible for any damage.
-K.R.
"I know what I know because I know what to do!"
Feb 07, 2010 | Philips 42 in. Plasma TV
Half of my screen plasma TV 50" is black. What I have to do to fix it? plhilips plasma tv model 50PF7321D/37
Your Television problem on vertical section.
Solve: If you repair itself replace vertical IC or thoroughly resolder dry any components.
Jan 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
LG 42PC3D plasma television -- screen split down the middle
Our 42" LG picture is also split down the middle. It doesn't matter if it is cable or a DVD. I would love to know if anyone has found out the solution to this prob. The TV is only 3 years old...
Jun 19, 2008 | LG 42PC3D 42 in. Plasma Television
42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Black Vertical Bar
It will burn into the screen overtime. The Akai units have a resistor on the address board that feeds the PDP that usually has a crack in the solder on one or both ends of it. There are about 4 address boards that are right below the panel itself and the suspect one is the board right below the line that is appearing. Have someone with solder skills repair it.
Jun 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
213 people viewed this question
Top Televison & Video Experts
