Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Can't load Hyperfonts on my pc
I have the futura software and auto-punch on my pc and went to load the hyperfont disk and was asked for the code.......put in the code and now it tells me that the disk that I have is unauthorized. I purchased this machine from ebay. The previous owner sent me these disk...and all of them worked until I went to install the hyperfont. Help!!
Try going to www.futura-support.com, then Service Updates. There you will see quite a few updates so have a read through and you will see a download for people having trouble with Hyperfont, Autopunch etc. Download this and your problem should be solved.
Posted on Apr 30, 2008
Hello I have the same machine Futura CE250, But I just have the the Autopunch software. I dont know why this situation. What about if you try uninstalling and reinstaling the software? my email frias.hector@hotmail.com Best regards and good look.
Posted on Apr 29, 2008
Singer futura xl 400 problems
Skipping stitches are caused by a bent or poor quality needle, and never by software.
Use only Schmetz needles if you want good results.
Use Classe, Singer, Unique, Tailorform etc if you want poor results.
Mar 14, 2014 | Singer Sewing Machines
Auto punch software issue
First, after you have installed the basic software and before you can install any add-on software, you must start your machine with the USB cable plugged in on both sides, so that Windows can actually install the driver. Then, start the Futura basic software one time, then close it--you don't have to actually do anything, just start it up. Then, check the Futura Support site http://www.futura-support.com. There is a patch you should run before installing the AutoPunch software for your model. Make sure you also download the instructions as well.
Jan 20, 2014 | Singer CE-200 Quantum Futura Computerized...
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
Dec 11, 2010 | Singer CE-200 Quantum Futura Computerized...
I have a Futura CE-200 but have a laptop with no cd-rom drive so i've been putting the installtion software on a thumb drive, copying it onto my latpop D-Drive and installing it from there. The initial...
For old Futura software optional features (AutoPunch,Photostitch etc.) can be installed only from original CD. You may upgrade your software to version 2.5.0.x that has more features and more flexible installation procedure, you may ask your closest Singer supplier about it.
Feb 19, 2010 | Singer CE-200 Quantum Futura Computerized...
Futura software on winds vista
well i fixed the problem. if anyone wants to know how, just send me $9.99 (fiya price) and i will be glad to share.
Jan 11, 2009 | Singer CE-200 Quantum Futura Computerized...
Cannot install and get the Hyperfont to work on Vista
Search for troubleshooting utility in your Futura folder, launch it and send report to Singer. It is quite difficult to determine the root of the problem without your pc configuration and Futura folder content info.
Aug 28, 2008 | Singer CE-100 Futura Computerized Sewing...
Using Hyperfont
hyperfont is a disc that you put into your pc which lets you use
the font (letters you type on your computer in windows true type)to be transfered to you'r embroidery machine and sewing on to
a garment, you can change the size make it Bold, Italic,Regular
The size depends on the size of your embroidery hoop.
Apr 19, 2008 | Singer CE-100 Futura Computerized Sewing...
Other brands of Software
You can only use the futura software, autopunch, hyperfont and cross stitch
Oct 29, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
228 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
