It is not the motherboard that is cooked it is the processor overheating to correct this problem you need to do the following
Remove the Heatsink from the CPU and re apply heatsink
compound to both the CPU and the heatsink then replace the heatsink onto
the CPU. the reason for the overheating and shutdown is that the
connection between the heatsink and the CPU has become "Aged" and no
longer transfers the heat like it should
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA
the leads from your
"((motherboard to your hard drive))" make sure they have a secure connection and
are not faulty or just replace them they could be faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they could
be faulty a computer
needs its connections to continue its cycle and have an end so any faulty leads
will end up with a computer error hope this helps
