Tv does nt turn on
My tv sharp mts stereo does´nt turn on, just make sound like "click"
tv sharp 20G S100
    Scholar:
  • 186 Answers
Sharp's are known for weaker flyback transformers. Odds are you need one too. Not a DIY project unless you have experience in electronics. Best bet might be to Recycle this unit and invest into another unit. Keep your eye open for garage sales too.
Posted on Apr 23, 2008
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
Audio Problem - Can't turn the 'stereo' feature on the MTS
what cable boxdo uuse can use s video out for video to tv and rca cable for sound left and right is it a hd tv then u wantto use coumpiunt cable or hdmi
Jan 11, 2008 | Toshiba 57H83 57" Rear Projection HDTV
Tv went to Widescreen how do I put it back to full screen on Sharp 25R-S100
Click here to download the user manual to your TV. It has all details.
Jan 13, 2013 | Sharp 25R-S100 25" TV
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
No sound at all. FAO is off Speaker says on. Set on stereo. Will an outside speaker work? Where to find speaker? Must use stereo?
just replace your speaker or resolder the audio amplifier,to check ur speaker you must full the wire and connect it to a 1.5v battery hear the sound if theres asound ur speaker is ok maybe the audio amplifier is the problem
Sep 26, 2010 | Sharp 27N-S100 27" TV
Hey there i have a sharp tv mts stereo pip and it turns off after 10 seconds.. i turn it back on.. and it turns off after 10 seconds.
i sujjest you download the complete 46 pages service manual from my ftp sight,and do a factory reset of the set,request it at computec40@hotmail.com
Nov 04, 2009 | Sharp 32F640 32" TV
Sharp 25R-S100 25RS100 SHARP 25" STEREO FRONT/REAR AV
Good day.
Try to check the crt socket. Also, check for the loose contacts along the Chroma IC. Like wise, there is a screen adjustment on the rear portion of the flyback. Try to adjust the screen.
Response is highly appreciated.
chris
Feb 24, 2008 | Sharp 25R-S100 25" TV
Speaker squeal
ok if you dont wanna replace the audio output ic in this set you can simply disconnect the speakers in the set but tape them up so they wont short out against anything and then you can run the sound into your sound system of choice if it has an audio outputjack
Apr 01, 2006 | Sharp 25R-S100 25" TV
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
