Its on my wifes toshibe satellite notebook. The screen went to gray and now won't load windows or when use restore disk the same problem
  • 41 Answers
Sounds like the display has gone bad. Most likely the inverter, which supplys high voltage to the tube that lights up the screen.
Does a monitor hooked up to the laptop display properly? If so this pretty much confirms that it is the display that is faulty. The only fix I can comfortably recommend to the do-it-yourselfer is to take it in for repair, though you may be better off replacing the whole laptop.
Posted on Apr 23, 2008
Toshiba Sattelite PRO L300 telling me checking file system C one of disks needs to be checked However it then says an error has occured and won't leave this screen !
Press F8 and choose command prompt.You may have to use a boot disc if you can't get c prompt.
Type cmd ENTER. From the Command Prompt type chkdsk /r/f ENTER. R and F are redundant for repair and fix, but does not hurt.
Oct 29, 2012 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite A105-S4014 15.4" Notebook with
If the drivers aren't loaded, it won't work properly.
Please check your model number as I cannot find it on Toshiba's database.
Try www.computers.toshiba-europe.com and let Toshiba detect your model.
Toshibe supports most models.
Nov 17, 2010 | Toshiba Satellite A105-S4014 Notebook PC
I own a Toshibe Satellite L350D-215 running windows 7, when I power on the laptop it brings up the Toshiba welcome screen then loads a screen stating that there is or has been a problem and you have...
Sounds like you need to run the recovery disk
If your have the Recovery Disk put it in and boot from cd/dvd,
[Push "F12" at the Toshiba boot screen to access the Boot Menu]
you will loss all your info,,
to save your info [pic's] you will need to plug your hard drive into a desktop with sata.. and back up you info that way then run the disk
if you dont have the disk you will need to get a new windows 7 dvd or contact toshiba for a new Recovery Disk set,
Some times they put the Recovery on the hard drive but i think you need the disk with this one.
May 16, 2010 | Toshiba Satellite L305D-S5874 Laptop
Toshiba Satellite Vista 32bit...Big start up Problems!
1. you could use the vista to reformat the drive.
2. you could use boot disk to do the same thing.
or
3. load again the vista for fresh installation.
Apr 08, 2010 | Toshiba Satellite A130 A135 Notebook
I cant fint my system recover drive, i want to reinstall visat on it, its toshibe satellite A135-S4427 please help
Most Toshiba computers do _NOT_ come with a set of "System Recovery" disks.
Instead, there is a program installed on the computer that you use to write your own set of CD/DVD diskettes, using your "blank" disks and your CD/DVD burner. Run the program to create a set of disks.
Or, when you restart your computer, look for displayed text like "press Fnn to start System Recovery". Press the named key.
Jan 27, 2010 | Toshiba Satellite A135-S4427 Notebook
My Toshiba Satellite L300 PC Notebook, just an year old and hardly used gives a blue screen and says press alt, ctrl + delete to restore but even with using the CDs provided in the package does not...
Usually the cause of blue screen is the memory stick try to remove the memory and clean the dust use eraser to clean the lower part. If the same things happen you need to repair the Operating System. Load the windows CD to repair. It will required to to press any key to boot from CD. Follow the instruction there.
Regards
PCmania
Sep 30, 2009 | Toshiba Satellite Pro L300 Notebook
Gray screen on start up
hi
ok the very first thing what u have to do is that disconnect the ac adaptor and take out the battery from the laptop and then press and hold down the power button without the adaptor and the battery for one minute and then connect adaptor and the battery and then turn on the computer and still if it doesnt boot try last known good configuration,try to go to safe mode and check it out or what u can do is u can take the computer back to the factory restore with the help of disk or u can repair the winidows with the help of windows os disk,chkdsk /r.......good luck
Jan 30, 2009 | Toshiba Satellite M35X-S149 Notebook
Turn on, asks for password, computer works for a min & blank scre
If you keep pressing F8 before Windows starts to load it should display a menu, if you choose "safe mode" it may then load into Windows. If you're using WinXP you can try a system restore - click start, all programs, accessories, system tools, system restore. It should display a calendar. Click on any date in bold and restore to that date. It may solve the problem for you. Did you install a new game or anything just before it went wrong?
Jan 24, 2009 | Toshiba Satellite A135-S4527 Notebook
Sound driver
Hi, I want to install sound driver on my laptptop model: Toshiba satellite L30. Please advise me.
Aug 10, 2008 | Toshiba Satellite L20-S310TD Notebook
Computers & Internet Logo
David Payne
David Payne
