FixYa.com
Tags:
ASUS K8V-SE Deluxe Motherboard
Cpu test
posted by pchrist on Apr 23, 2008
is it better to put them on the tops or the bottoms??
Comment by pchrist, posted on Apr 23, 2008
is anything on the back of this motherboard supposed to touch? could i clip some of the leads on the back if they are too long? there is a big heat sink under the cpu can that touch?? i know it has to be a short somewhere on this board i just not sure where to check.
Thanks
Pete
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
jemthy
Rank:Wiz Wiz
Rating: 82%, 50 votes
on the top of the screw to prevent the metal screw to ground in the motherboard. Make it sure that the screw only grounded to the casing. Check also some metal in the back of the casing maybe it also the cause of the motherboard grounded.
Comment by jemthy, posted on Apr 23, 2008
It's ok. to touch the big heat sink of the processor. But don't touch some parts in the motherboard to avoid the electric discharge from your body to the motherboard. It's ok also to clip some long tip on the back of motherboard but avoid to scratch the board to avoid damage the connection of the board.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Motherboards problems?
Motherboards
HI I need driver
mother board: Lite-On NR146... Answer This...
Motherboards
no sound
i have problem with audio... Answer This...
Motherboards
microsoft says my os is not an...
Is there another way to get a... Answer This...
Motherboards
change the start up logo on a...
hi i would like to know how... Answer This...
Motherboards
urgente¡¡¡¡...
como puedo hacer para... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
