Cd does not read every time
Have a marantz cd player when it eventually reads the disk it will read all the tracks. problem is getting it to read a track in the first place.  it is a marantz cd11 mkII I have to keep opening and closing the draw and then it will read. but then scared to change the cd as it will fail again to read another cd when I change the cd
  • shazbrit Apr 23, 2008
    thank you I will try that other than that I will part it out sad
    Scholar:
  • 186 Answers
I love Marantz! They make quality products that last and sound excellent! Most likely it a dirty lens. When a lens gets dirty, it can't read the cd as accurate. Unplug it, remove the cover, locate the cd lens take a q-tip lightly dipped in rubbing alcohol and rub it lightly on the lens (don't drip it too wet). This should help. Sometimes they also have a weak laser which can cause the same problems, but try the cleaning first.
Posted on Apr 23, 2008
My cd-48 sometimes gives disc info but reads no disc when play is pressed???
i found my dads Marantz CD-48 on the attic and had the same problem. Some CD`s the player was able to play instantly others not, getting the Error Message after trying to read the disc. My problem was solved after i opened it up and cleaned the linse of the player with a cotton swab.
Mar 10, 2014 | Marantz CD-48 CD Player
Marantz CD-5000 CD player
If I may add to XX's post and with his indulgence...
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image below.
Image was adapted from How CD Works.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 22, 2008 | Marantz CD-5000 CD Player
Hi _ I have a Marantz CD player a littl;e over 6 years old. Performed perfectly until today, when it started inserting brief gaps in the music, approx 1-2 seconds; at the same time the track / time...
laser cleaning cd's very rarely work. the only thing they are good for is if there is a build-up of dust on the lens. Sounds like you most likely need to have the laser replaced.
Feb 11, 2014 | Marantz CD5001 CD Player
We have Marantz PMD 325 CD players. Usually TOC REading comes up when you put a CD into the player. However sometimes we now get the following message "PMA Reading", What does this mean.
Hi Wendy CD-Rs and CD-RWs have a component that ordinary music CDs do not have -- an ...This additional track space includes the power memory area (PMA) and the ... which tells the CD player what part of the disc it is reading at any particular time. ...uncorrected error on a music CD only means a bit of fuzz or a skipping noise. GOOD LUCK !
Jan 05, 2014 | Marantz SA8260 CD Player
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
My Marantz CD63SE SPECIAL EDITION CD PLAYER won't read discs
Most likely, new optical (lazer) pick up required to solve this issue.
Nov 30, 2009 | Marantz Audio Players & Recorders
Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Sep 14, 2009 | Teac CD-P1250 CD Player
My one-year old Marantz CD5001 CD player
these models use the 12.1 philips laser mechanism and it is a very common problem for failing to read discs.
various technics / marantz / philips / cyrus cd players etc also use it and are plagued with the same fault.
it's a 90% chance the laser is dead!
philips realised the unreliability of this laser and uprated it to the identical looking VAM-12.
do not dismiss the spindle motor as these also fail quite alot on this mechanism.
hope this helps.
Dec 20, 2008 | Marantz CD5001 CD Player
Kenwood KDC-X589 seems like the CD player doesn't put out sound
you have to change the cd read setting it might got set to cd read 2 it needs to be cd read 1 in standby mode press menu button scroll through with track button till you see cd read and set it to cd read 1 if not in standby mode try in cd mode same steps
Jul 03, 2008 | Kenwood KDC-X589 CD Player
NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Nov 06, 2007 | Audio Players & Recorders
267 people viewed this question
 Grubhead
Grubhead
