Question about Canon PowerShot S3 IS Digital Camera
My camera will not turn on
I have replaced the batteries, I have removed the card and put it in and when I put the card in or shut the battery door the red light comes on beeps a few times and shuts off.  It worked only a few hours before
  • Anonymous May 13, 2008
    Camera will not turn on. Batteries were replaced. Memory card was removed and reinserted. Nothing works.
    Scholar:
  • 75 Answers
Check to see that you are using the right kind of batteries (NiCad, Lithium, etc) Not just size, but check what knd the camera needs . Some batteries come labeled for 'Photo' or Digital Devices', but are not the right type for your device, so will not work, and will result in odd bhaviors like what you are seeing > not enough of the right juice.
DigiChick
Posted on May 29, 2008
When i power off it shows it is still turned on
First, make sure that you downloaded any photos so that you don't lose them. Next, open the battery cover and remove the battery. Count to twenty, then put the battery back. Try switching on and off and see if that cures the problem. If not, remove the battery again and look to see whether there is a secondary lithium watch size battery in the battery compartment. If so try removing and replacing it. Then put the main battery back and try switching the camera on and off. Then remove the memory card and try switching it on and off. Then, if it still won't shut off, try going through the menus and reset the camera to factory/default settings.
Oct 21, 2013 | Canon EOS-10D Digital Camera
HP Photosmart M627
Try first removing battery and putting back.
Aug 01, 2008 | HP PhotoSmart M627 Digital Camera
Won't turn turn on. A red and green light comes on, but nothing on the screen.
Step one: Reset the camera
  1. If you have an optional memory card installed, remove it.
    NOTE: Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.
  2. Remove all batteries from the camera for at least five seconds.
  3. Reinsert the batteries and close the Battery/Memory card door.
  4. After verifying that the camera works without an optional memory card, reinsert the card if you removed one in Step 2.
Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
  • If the is not resolved , continue with the next step.
Step two: Check for damage or corrosion on the batteries
  1. Open the Battery/Memory card door on the camera.
  2. Remove the batteries.
  3. If the batteries are damaged or show corrosion, replace the batteries.
Step three: Recharge the batteries
  1. Recharge the batteries or replace the batteries if they are damaged or will not charge.
  2. Try turning the camera on after the batteries are fully charged or have been replaced.
Step five: Ensure the batteries are installed correctly
  1. Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
  2. Try turning the camera on.
Step six: Turn on the camera without the memory card
  2. Remove the batteries and optional memory card from the camera.
  3. Wait 15 seconds.
  4. Re-insert the batteries into the camera, but not the memory card.
  5. Try turning the camera on.
    • If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
    WARNING: Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
Step seven: Service the camera If the camera still will not turn on, service the camera.
Mar 04, 2010 | HP Photosmart E327 Digital Camera
When I turn my camera on it stays on for a few seconds and then shuts itself off. I even put brand new batteries in it and it does the same thing
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 14, 2010 | Kodak EasyShare Z700 Digital Camera
Camera wont turn on
  1. Step one: Reset the camera
    1. If you have an optional memory card installed, remove it. (Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.)
    2. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
    3. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
    4. After verifying that the camera works without an optional memory card, reinsert the card, if you have one.
    Step four: Ensure the batteries are installed correctly
    Step five: Turn on the camera without the memory card
    3. Wait 15 seconds.
    Step six: Connect the camera to the optional AC power supply
    1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
    Step seven: Service the camera If the camera still will not turn on, service the camera. Cause The following conditions can cause the camera to not turn on:
    • Improperly formatted memory card - memory cards should be formatted in the camera they are going to be used in
    • Corrupt images on the memory card
    • More than 300 pictures on a memory card
    • Damaged batteries
    • Dead batteries
    • Incorrectly installed batteries
    • Damaged camera
Jul 19, 2009 | Leica C-Lux 1 Digital Camera
My Photosmart E327 won't switch on.
Resetting the camera
If your camera does not respond when you press any
buttons, try resetting the camera as follows:
1. Turn off the camera.
2. If you have an optional memory card installed, remove it.
3. Remove the batteries from the camera for 5 to 10
seconds.
4. Reinsert the batteries and close the Battery/Memory card
door.
5. After verifying that the camera works without an optional
memory card, turn off the camera and reinsert the card if
you have one.
Mar 03, 2009 | HP Photosmart E327 Digital Camera
Have put in a memory card, But camera keeps displaying memory card full
Try reformatting the card. Use your camera to do it, not a computer.
Dec 14, 2008 | Cameras
Unable to shut door on battery and memory card cover
some memmery cards have to click in. press in click, press in click out. or memmory card needs to be turned around.
Feb 01, 2008 | Olympus Stylus 790SW Digital Camera
Coolpix 8800 shuts down
Make sure to use good NiMH batteries. Another possiblity is a problem with the card. Borrow a card and see if it has any effect. check to see that the pins in the card slot are all aligned, none out of place. check that the card door and the battery door close firmly, with some pressure. The camera can shut down when it has a problem detecting that the doors are closed. When it does turn on, play with the zoom without taking pictures, zoom in and out, if during zoom the camera shuts down then you might have a lens problem, something is malfunctioning in the lens mechanism and the camera shuts down to prevent damage. Good luck
May 19, 2006 | Nikon Coolpix 8800 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
71 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
