posted by pchrist on Apr 23, 2008
getting a system failed cpu test only when installed in a case will work just fine if out of case
Comment by pchrist, posted on Apr 23, 2008
on the top or the bottom of the board??
Best Solution
I think the problem is the mounting screw of the motherboard to the casing is grounded. You need to put some plastic insulator to the metal screw to avoid the grounded in the board.
Rating Locked! (?) pchrist has rated this solution as FixYa!
Suggest a new solution for this problem
Post a New problem for ASUS K8V-SE Deluxe Motherboard
Email this problem
Email this problem
Can you Help with these Motherboards problems?
Repair Service
Find Motherboard Repairman Near You:
