How to factory reset a philips 55pw9363, also service menu codes
  • 121 Answers
You would need your service manual for that because there is a lot of settings that will screw your tv up if not done properly heres a link where you can get a service manual with free online tech support for your tv
http://servicemanuals.vstore.ca/
Posted on Apr 23, 2008
Need 55" Phillips HDTV Manuals Model #
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=EN&scy=US&ctn=55PW9363/17 you can get the user manual and any other information needed for this model from that site. if you were talking about the service manual then let me know i may be able to get that as well good luck
Jan 10, 2011 | Philips Televison & Video
Brightness and dark scene problems
you need to check your picture menu to verify you contrast is at max and brightness level is at approx 55% . if good , call for service and have htem check the setting on the screen controls. sometime they drift with heat, cold and age. when this happens, they usually have to reset the grey scale (black and white content) of the picture. Beyond that could be a defective red crt drive pcb or red crt or small signal panel.
Apr 20, 2010 | Philips 55PW9363 55" Rear Projection...
55PW9363 55 Remote control code and how to obtain a copy of the manual
Phillips Codes -003-004-008-012-019-062-068-069-075-076-086-087-088 Call Mats for Manual they might have one 1-800-628-1118
Sep 27, 2009 | Philips 55PW9363 55" Rear Projection...
Pink and greenish lines creating a double picture
with your remote go to your menu and find convergence. Follow the instructions to auto set convergence. if that don't fix it the problem convergence panel if bad.
Mar 15, 2009 | Philips 55PW9363 55" Rear Projection...
Double color
If going into the service menu does not adjust out, you should take it to the shop. To enter service menu use original remote and press 0-6-2-5-9-6 then menu
Jan 07, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 55pw9363 next problem
Have you change the RGB setting to Y/Yb/Yr?
You can change this option in the menu - install then go all the way to the bottom
Nov 17, 2007 | Philips 55PW9363 55" Rear Projection...
DOWN HILL
Do NOT make any factory mechanical adjustments! Geometric alignment done electronically in the servicer mode needed.Senior tech skill level only.
Aug 20, 2007 | Philips 55PW9363 55" Rear Projection...
Philips 55pw9363 factory default settings
Yes,there is almost always a way! you will need the CD ROM literature for your model--it will list the normal range of settings. My reserved question is what caused the overscan and why did you decide to go in the servicer menu to "fix" the problem???? You may have some convergence issue,also.
Oct 17, 2006 | Philips 55PW9363 55" Rear Projection...
Philips 55PW9363 Service Menu - Geometry settings help, picture shifting at times???
If you are doing the labor you should wait and replace the new part and while you are at it check for loose conections in the horizontal drive circuit since all symptoms might be related,but they are doing all the work they should address all the problems you have,settings in the service menu dont just change on their own and are adjusted only when a major comp[onent has been change like the convergence.
Oct 03, 2006 | Philips 55PW9363 55" Rear Projection...
Televison & Video Logo
258 people viewed this question
Top Televison & Video Experts
Electro Med Services...
