Ok got a laptop problem, for my acer aspire 3000, im sure its the lcd, i turn it on, sometimes it works fine, other times it doesnt, http://www.fixya.com/lpgetsolution2.aspx?cmpid=6190308000158&gclid=CKzY4OSR8JICFQm4sgodfA3b3w this website is basiclly how it is, but a mixture, ive brought it to places and said dint know or no problem at all with it. example 1, 2 , and 7 happen, and also, starts up with a white screen sometimes, which ive read means the lcd inveter is bad, but, alot of times it works fine, but generally when you move it, that happens, and gotta move the screen back and forith to get it back or reset it several times, sometimes it comes on right away but alot more often it takes time. i double checked the lcd inverter data cable, it seems like no loose conection. so not to sure.. thanks
  • xcultlifex Apr 23, 2008
    i did check the cables, and they do seem fine, but im not to sure, ive moved and resat them and nothing, there is one cable coming out of the lcd cable tho, that is sticking out, and has a cap on it type deal made of metal. i put tape over it to make sure it wasnt that hitting something and shorting out but no its been a part a few times now, do you think its worth buying an inverter and inverter cable an lcd cable to try and see if those are the problems? o and i put it intio an external screen and worked just fine, forgot to mention that
    nope it isnt, i bought it refurbished, im assuming it may have had issues like this before, cause it seems the inverter and cable have been replaced, i emailed acer, and they want 450 just to be sent in, but im gonna take it to a place tomorrow see if they can see whats wrong with it or not, ive broughtr it to some and it worked perfectly fine, so i dunno maybe it will work out this time, thanks alot
  • 41 Answers
Unfortunately, you will probably have to open up the laptop, and check the seating of the cables inside both the base and the LCD. It sounds like a loose connection, or a broken wire. I had similar issues with a Dell laptop, and it turned out to be a wire going to the ccfl tube (The backlight) that was shorting out against the case of the laptop when moved. Also, just try to re-seat the connections, it sounds like you have already had it apart. The cables should come off easily, and go back on with ease too, but do not attempt if you are not experienced, or at least comfortable with this type of thing.
Posted on Apr 23, 2008
  • John Dean
    John Dean Apr 23, 2008
    Probably not, it really seems to be a connection issue, as it works until moved. Is it under warranty? I am assuming no... They never break when they are under warranty.
Acer Aspire 3000 Help required to restore to factory
Acer does have a good support team, I think you would be further off getting the recovery disc, it comes with all the drivers eliminating guess work, and it is there if it is needed again.
Apr 01, 2012 | Acer Aspire 3000 Notebook
I have an acer aspire 3000 series and when I turn it on the acer logo shows up on the screen, but after that the screen just goes black.
Hi
If this problem is a recent one and the notebook was working fine
You could try to start up in safe mode then do a system restore back to when you reckon it was ok
Nov 13, 2010 | Acer Aspire 3000 Notebook
My acer aspire 3000 is playing up. i can turn the laptop on, but most of the time it freezes and i have to take the battery out a fair few times until it works okay. Is this a problem with the battery or...
Hard to tell without looking at it! First try cleaning it up in case its junk running thats making it freeze from lack of resources.
Remember that Norton and McAffee being famous are most likely to be targeted, try AVG for antivirus and for spyware/malware scanners try as many (reputable) ones as you can be bothered to go through, the trick is to use lots of different ones as some pick up what others dont.
If that doesnt work, you can try reinstalling the operating system, it could be corrupted system files. Make sure you put your data safe first!
Oct 29, 2010 | Acer Aspire 3000 Notebook
Laptop is freezing randomly. sometimes doesnt work at all. sometimes only parts work.. keyboard, mouse etc. sometimes wont turn off. sometimes freezes then responds 10 min later
Seems like really hard problem, maybe something with laptop motherboard. But on other side, it can be just some virus. Try google for Eset Online test and let it scan your computer for viruses. its free. Always use good antivirus. One of best is Avast. And its free. Download it from avast.com (Home edition).
Sep 21, 2010 | Acer Aspire 3000 Notebook
Acer Aspire 5920 won't turn on
check the ram chips havent come loose, i had this problem with an acer aspire 5315 (fixed myself). if that doesn't work, check the lcd cable
Dec 26, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire 5570z white screen
its either going to be a problem with the lcd, inverter or output from the motherboard probably.
Best thing to do is to try a different lcd with a different lcd cable, then if that doesn't work, then try to get a different inverter, if that doesn't work then you'll know for sure its the output coming from the motherboard.
Alot of times the LCD's go bad but the lcd cables go bad cause they are flimsy and the wires break inside.
Look on Ebay cause you can easily get these parts cheaper then most places.
Aug 09, 2009 | Acer Aspire 5535-5050 Notebook
Screen turns white
You need a new led replacement in your LCD on your laptop. It would be cheaper to do that than buying a LCD. The Inverters for the LCD are easy to replace. make sure you check the model number on your laptop.
Jul 19, 2009 | Acer Aspire 4315-2490 Notebook
My Acer Aspire 3000, Keybourd Stopped Working
i had the same problem. the battery does something during startup and the only way i found to fix it was to turn it on without a battery while its plugged into the adapter, or leave it in standby instead of shutting down... i dont know if theres a better way, but thats what i do.
Apr 11, 2009 | Acer Aspire 3000 Notebook
Acer aspire 5050 display faliure
you cant see the damage physically, i think it has internal parts that is damage that is why it won't work. try to check internal display wirings of your lcd.
Mar 12, 2008 | Acer Aspire 5050-3242 Notebook
Acer aspire 3000 doesn't charge
are you sure the battery is good? How old is the system and battery? Do you have any way to check voltage at the battery terminals?
Aug 29, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
