Question about Philips DVDR75 DVD Recorder
Problem with DVD RW being read
My Philips DVDR75 recorder hasn't been used all that often in the past 3 years, but I have been using it more now to replace VHS when recording from TV. It has been happening a lot lately that when I turn on the machine, the disc in it has data on it but the machine says the disc is empty and doesn't show up the free titles still available so I turn it on and off over and over until finally it recognises it which may take up to 1/2 an hour! And other times it says the disc contains unknown data so press ok to open tray etc. Today it happened again, and this time it ticked me off the most as it said empty disc but I knew it had important data on it and no matter what I would do it just wouldn't read it so I hit record for a few seconds and now all that's on the disc is the few seconds. Where did my data go?? I would understand if I lost those few seconds but I lost over an hour of individual chapters. Please tell me I can fix this. PLEASE.
  • 1 more comment
  • Lisa261 Apr 23, 2008
    Thank you for your response.
    The machine has barely recorded 50 hours worth of data since the day I bought it so I don't understand why anything would be failing. It has no problem accepting a normal pre-recorded disc only the RW ones. And it doesn't record a pre-programmed program anymore as it won't recognise the disc inside.
    My biggest issue of the moment though is losing the data that was on my disc. Is it still actually on the disc? Can I retrieve it somehow??
    I have used disc cleaner, it doesn't seem to make any difference. The machine just doesn't seem to like the RW discs which is ridiculous considering the point of the machine! I just want the machine to work properly and I want my data back!
    My PC doesn't recognise it as a dvd or anything...I also tried it in another DVD player and the main data wasn't there either.
    Is there anything else to do?? Would a computer repairer or someone like that be able to retrieve it?
    Brigadier General:
  • 3,614 Answers
Typical retail CDs that you purchase from a store have had their data or music pressed (or stamped) onto the disc via an intricate injection molding process. Tiny raised and lowered areas indicate how data is stored and how it should be read. After this imprinting process, a thin layer of metal (such as aluminum, gold, or silver) is applied to create a reflective, readable surface, followed by a clear plastic layer that serves as armor against scratches.
Posted on May 04, 2008
    Genius:
  • 1,142 Answers
Hi, as far as you data is concerned you can verify that in a computer try reading the disk in a computer drive, and that should tell you if you have the data still there in the disk or has been over written, in case its over written then there is no possiblility you can recover it or else you can see your self.
And as far as your dvd recorder is concerned as its not reading disks its an intermittent problem its always better to replace the weak lens or you get a new recorder.
Please rate the solution if you find this helpful as fixya or else please leave it blank and dont rate any. Thanks
    Genius:
  • 3,422 Answers
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck..
Please don't forget to rate the solution.
  • 3,037 Answers
With this system, unfortunately the symptoms you describe sound like the laser assembly in the drive has started to fail.
The symptoms usually start with the recorder failing to recognize pre-recorded disks, then you get "DISK ERR" during recording, which becomes more frequent. Then it becomes almost impossible to record more than half an hour of a program.
The symptoms are confusing because some DVD+RWs fail more readily than others.
Please let me know if you need any additional help.
Thank you for using Fixya and Good Luck to you
Posted on Apr 23, 2008
  • Benjamin Patri
    Benjamin Patri Apr 23, 2008
    I'm sure a computer tech could retrieve the data off of the DVD, if you want the recorder working again, then the laser assembly will need to be replaced, they tend to wear out and if you replace that you could probably read your DVD and retrieve the data off of it
  • Benjamin Patri
    Benjamin Patri Apr 29, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
    Genius:
  • 1,226 Answers
Please try disc cleaner, and try to use new disc after cleaning.
may this help,melnavz
  • Emelio Navaja
    Emelio Navaja Apr 23, 2008
    hello again,
    In your case that only the recorder doesnt recognise RW then, there maybe someting wrong with the lazer recorder. If you did not try to open the recorder. you can try to open the recorder and then clean manually the optical lens with soft clothe or any material(do not use liquid celaner) which do . Oserve the alignment of the optical to prevent damage.
    If this not work maybe the optical lens maybe busted.
    May this help, melnavz
  • Emelio Navaja
    DAta on the disc am sure that it is still there, you can try it in another cd rom or insert it in DVD rom of the PC am sure maybe pc can read it.
Can't record with dvd recorder from hd digital cable box
Hello, Ciprian -
Your television service provider (cable or satellite dish) provider may not allow DVRs which the company does not provide. We have AT&T Uverse as our cable TV provider and must use the DVR the company provides (and charges for.)
Have you checked the policies of your TV service provider regarding the use of DVRs not provided by the service company?
Dec 21, 2017 | Philips DVDR75 DVD Recorder
Tip
Make a DVD+/-RW compatible for recording with a Philips DVDR3380
Sometimes you will have a used DVD+/-RW that already has titles recorded upon it but when you attempt to record another it won't let you even though you have space left at the end of the media.
This can happen if you delete title 2 when you have a totoal of 3 titles recorded it gets confused, there are several options available to you. Sadly both will erase all the titles that are on the media unless you scan the DVD titles in with TMPGEnc v4.0 Xpress prior to the full erase, this is your safest option if this can't read the DVDR format nothing will be able to.
  • Blank on a PC using ImageBurn this will lay down chosen format for you if you have a DVD+RW you must select this option etc...
  • Use the DVD3380 to do it for you follow the following 4 steps this is the only way you can do it sucessfully.
  1. Put the DVD in the tray as usual if you press <REC> you will see a no entry symbol in the bottom right-hand corner.
  2. Press <REC SOURCE> button to toggle to the desired input I use EXT2 for my SKY+ Box connected via a gold plated SCART lead.
  3. Press <REC> button and you will see the following window appear000c226.jpg
  4. Press <OK>
After the recorder re-formats the DVD+/-RW media it will be available for record again, either way it will give you what you want. when the thermometer bar gets to 100% simply press <DISC MENU> and you will see that it has been blanked to its format DVD+RW or DVD-RW depending upon the media.
on Jan 11, 2010 | Philips DVDR3380/05 DVD Recorder
Disc reading display
Have you tryed to clean it wit a lens cleaner. Sounds like just needs a good cleaning.
Hope this helps you
Jan 12, 2010 | Philips DVDR75 DVD Recorder
Error code E 4 54040990
jamesgranger - I think your DVD recorder is still having trouble reading the DVD+RW. It should not have a problem using a DVD+RW many times. Try taking the DVD+RW and put it in your computer. Find it in Explorer, right-click and choose "Erase". Then try to record to it using the DVD recorder again. If it works, you can use this to record, though it might be a pain.
The fact that your machine will record to the +R means that it works. Failing to work (record or erase) on the +RW means it's not reading it well. I would try running the lens cleaner again if it were mine. Also, I would make sure that the unit didn't have a lot of dust in it. If you can, power it off and use some spray-air to be sure there's no dust. You may have cleaned the lens, but if there's a lot of dust inside the unit, it will quickly find it's way back to the lens and you'll have the same problem. Michael
Jul 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My Philips DVDR75 is totally locked
Try unplugging it from the mains for 2mins
Mar 23, 2009 | Philips DVDR75 DVD Recorder
Playback problem
Check your dvd player specs. It may not read dvd-r disks. Hope this helps.
Jan 13, 2009 | Philips DVDR75 DVD Recorder
Philips dvdr 75
Hey there Dante471, you can roll back the driver to it's original setting before the update. Control panel / Administrative tools / computer management / device manager / your dvd drive / driver / roll back driver. I suggest you shut down all other applications, and follow procedure with a restart. If further details are required or you need elaboration on method, let me know. Good Luck!
Jan 02, 2008 | Philips DVDR75 DVD Recorder
Philips DVDR75
Alignment or dirt problem...accordianman
Oct 15, 2007 | Philips DVDR75 DVD Recorder
Philips DVDR75 DVD Recorder Logo
180 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
