Question about Cobra 148 GTL 120-Channels Base CB Radio
Old Cobra148 GTL
Transmits modulation if you are within 500 feet?
Meter does not move? So I am not able to calibrate it.
It is an older model. Have had it for twentyyears or so?
Wher might i get it repaired in MA? Thanks.
  • Dean Pitts
    Dean Pitts May 11, 2010
    Are you sure it is a problem with the unit? I most comonly see this happneing when there is a problem with the antenna or coax. Usually if you can not reach out at least a mile, your antenna may be broken, not getting a connection with the center connector with your coax, or the center conductor of the coax is broken. I would try it with a known good coax and antenna.
    Another common problem I have seen is having the small round plastic piece, which is used to stop the antenna from being grounded, put under the mount. You need to make sure it us under the antenna and on top of the mount. If your antenna is grounding out to the vehicle, it is like you have no antenna at all.
    Dean
    Rollin CBs
    Scholar:
  • 67 Answers
Or maybe the final is out.. just TX on driver alone.
Posted on May 25, 2008
NEEDLE MOVES ON RECIEVE LIGHT BURNT OUT AND NEEDLE DOES NOT MOVE ON TRANSMIT IN S/RF,SWR OR CALIBRATE BUT RADIO TRANSMITS GREAT..
try blowing some canned air on the knob and switch to remove dust , also try a dash of electrical component spray on them , then see if it works.
May 06, 2015 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 1000 gtl modulation/swr meter vr adjustment
you are not matching it correctly. get hold of a friend that knows how to match it and see if he will help you.
Mar 18, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
No transmit on 148gtl
First is check to see if SSB transmits or not==if it does the AM regulator on side wall of radio is bad.
Second with a meter and no power on--test the driver and final for shorts or open.
If one is bad replace both.
let me know what you find.
Apr 29, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
148 gtl receive issues
The problem is in the audio output chip usually bolted to the inner chassis. Sometimes the chip developes a hairline crack, replacement recommended.
Mar 14, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
How do I calibrate my stanley laser level
to calibrate you need to have an area 75 to 100 feet in distance. place laser on tripod 20 feet from one end, take measurements on short and long end, then move laser to center of range and take measurements on both ends . the distance between both sets of marks should be within + or - 1/4 inch if not move level screw to move beam to center then center bubble
Jun 17, 2010 | Stanley 77 156 RL100 Manual Leveling Dual...
Where do you do the setting to increaese output on cobra148 gtl cb radio
You can try this, take the cover off (speaker side) look for TR24 and cut it, one end will do, the remove these, look for R126, and change it to a 2.2k resistor re soldering it in place, makes no difference which way you install it, then look for R124 and replace it with a 2.2k resistor doing the same, then look for L37 and L38 and with a watt meter in line putting a three foot coax jumper in line from radio to watt meter on the lowest scale, tune them for maxim RF output....hope this was helpful...
May 20, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
No modulation with strong carrier
sounds like your Audio Output went out......not audio chip....may be your voltage regulator also....your voltage regulator IC is heat sunk....do you have a schematic?
Jan 23, 2010 | Cobra Radio Communications
Please explain a 10 meter am/fm radio
Okay.
You do set this up like a regular CB. The meters refers to how long the waves are. CB is 11 meters. So its very close. The antenna woud be tuneds slightly shorter. Use the SWR meter in the radio to calibrate just like you would a normal cb.
Now for the ABCDEF knob. each letter is 40 channels in the band. So A would be 1 - 40 channels, then B would be the next 1 - 40 channel frequencies. You use the frequency counter in the radio(providing that model has one) to tell what channel you are on.
Here is some info one the frequencies in the band.
Now for AM and FM. this is the type of modulation you are using for transmit and receive.
CB transmits on AM or SSB. Amplitude modulation or Single side band. Most CB radios only have AM. But some also have SSB. None will have FM.
FM is frequency modulation.
10 meter radios can have AM FM SSB and DSB depending on the model and options it comes with.
So your radio has 6 ranges for freqency. each is 40 or 50 channesl. Not sure what model you have. If it has 40 then you have 240 channel freqencies.
with AM and FM, you double that, because you can talk on AM or FM on all the channels. If you are on AM and some one transmits on FM unless they are really close, you will not hear them at all, but if you do with will just be garbbled noise.
Also Am and FM both work a little different with range etc.
Now, you may be able to talk on the CB channels as well. Cb starts at 26.965 MHz and ends at 27.405 MHz. The channels are all .010 MHz appart.
Hope this helps
Dec 09, 2009 | Radio Communications
Puts out very little
output transistor gone or power turned down on front control,
May 09, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra148 gtl Meter malfunction.
Sometimes if your SWR is to hi it will burn
out the final output trsnsistor.
Mar 16, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
