Question about Maytag Neptune FAV6800AW Top Load Washer
To Remove front panel
Washer Model FAV6800AWW
    President:
  • Maytag Master
  • 2,651 Answers
Try inserting a putty knife perhaps 3 or 4 inches in from either side, bewtwewn the gaps wherew the main top meets the front panel, there are relaese tabs that when depressed the top will lift up, theres then 2 5/16 sdcrees attaching hte front panel to machine. there should also be a service manula taped inside there as well
Posted on Apr 23, 2008
Make sure that you use a plastic (1" -1.5") putty knife!
Posted on Oct 04, 2008
  • 4 Answers
Most washing machines have two little tabs at the base of the machine where the front panel meets the adjusting legs. Push down with your thumb ( or putty knife) and then pull the front panel towards you. It then should unclip. Do this on both sides. Pull the front panel out @ a 45 Degree angle and it should then just drop out.
Posted on Jun 23, 2009
3 Suggested Answers
dh1200s
  • 335 Answers
SOURCE: how to get front panel off neptune fav6800aww washing machine
Just a quick search in this forum fot "Front Panel" returned this post which says it better then I could.
http://www.fixya.com/support/t538238-remove_front_panel
Posted on Jan 18, 2009
SOURCE: removal of front panel of a stack washer and dryer mod
Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
Posted on Feb 07, 2009
My washer won't agitage on my maytag washer model fav6800aww. first started with a squeaking noise
Move the motor or pulley out of the way a bit and remove the old belt and replace with new, unstretched belt, tighten the motor or pulley and that is it.
Nov 14, 2015 | Maytag Washing Machines
Model fav6800aww drains during the wash and rinse cycle but does not drain during the spin cycle. it give an dc code during the spin cycle which i know that means unbalance but what does that have to do...
Clutch issue and possible time for a tub seal replacement
Google this for a post that covers the Clutch removal and inspection/repair;
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Google this for Outer Tub bearing rebuild;""
FAV6800A/FAV9800A Outer Tub bearing replacement""
Aug 20, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Neptune TL Washer FAV6800AWW need owners manual
Google This ""Neptune TL Washer FAV6800AWW""
5th post down is a link for the FAV6800A/FAV9800A SM.
Aug 18, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Yes I just want to know I it's worth fixing this prob. I have a maytag Neptune tl washer model fav6800aww it's starts fine but after 3 minutes it stops on wash cycle an after 5 minutes Lr shows on...
Lr error code is locked rotor. Could be a couple different issues.
Google this phrase and read thru the post ""[FIXED] Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin""
Post in that forum if you want to DIY I do not offer DIY help here any more.
Jul 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Od code - model FAV6800AWW - cycled power, no joy. Will not run
Could be a lid magnet out of posistion or broken wire from magnetic reed relay in Left Hand Lid Lock.
Google this ""Sticky: Neptune TL Washer FAV6800AWW""
I have repair notes to help you Troubleshoot and DIY the repair. 5 or 6 post down in the sticky you will find info to help you. This site is terrible for DIY folks. You have lost signaling thru the Left Hand Lid Lock to the Control Board.
There is a link to the Service manual in that Sticky. If you need additional help I will jump in............D*ick
Jun 25, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Fav6800aww machine wont stay balanced move the clothes around it starts back up for about one minute then stops code comes up dc thanks earl
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
In that Sticky I discuss what is the cause of DC or UC unbalance errors and the fix.
Apr 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL ( Model # FAV6800AWW) washing machine does spend but clothes still soak after it done. when you spend it by hand, it only spend in counterclockwise.
Any error codes. What happens if you start a Spin Only Cycle witht the same load? Does the times stay stuck at xx minutes in the LED display and the machine constantely starts and stops?
The more info on your problem the better.
Do you want to DIY the fix? Google this; Neptune TL Washer FAV6800AWW see the 5th post down here for general info and the Service Manual. If you want to try to DIY the repair I will help.
Apr 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My MAytag will not spin the water outta my clothes on spin cycle
If you machine is a FAV6800A or FAV9800A don't worry about the last two letters of the model number.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help.
Feb 28, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Need instructions on how to remove the tumblers from the Maytag Model NO. FAV6800AWW, washer. Took off the caps, but not sure how to get the plastic piece off underneath that's holding the tumbler...
Did you remove the #20 torx screws holding on the tumbler?
See Page 37 of the Service Manual
Do you have the FAV6800A/FAV9800A Service manual?
If not google ""Sticky: Neptune TL Washer FAV6800AWW"" and I will help you at that forum.....d*ick dh1200s
Jan 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
How do i get to the drainage hose in back of neptune FAV6800AWW?
You have to remove the front cover from the machine.
Do you have the FAV6800A/FAV9800A Service Manual?
I'll see if this site can let me post a pic of the wash tub removed. In this pic you can see the Drain Pump/Pressure Switch and drain line on the right side of the machine. There is no side or rear panel access.
What is the issue? Won't drain?
I would suggest you Google "Maytag neptune FAV6800aww wont spin" this forum has a Sticky for Maytag FAV6800A and FAV9800A machines and you can get the Service Manual from this site. I feel it's a better DIY site.
OK let me see if I can attach a pic;
Jan 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
1,426 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
