Brother MFC 1750 fax prints only left half of page. New print cartridge does not help.
  • jkelly345 Apr 23, 2008
    The print cartridge for this model has no metal parts on the outside; the exterior is
    completely plastic. Inside the cartridge is a roll of black film rather than toner.
  • 3,037 Answers
I would check to see if the metal connections between the print cartridge and the machine are clean, wipe them off with a clean cloth even if they look good.
See if that helps at all
Posted on Apr 23, 2008
  • Benjamin Patri
    Benjamin Patri Apr 23, 2008
    check to see if the print head is clean or if it has a bad connection then. you could try buying a print head cleaner but I would try and take a cloth and see if you can clean up the connections and the area where it prints from and check for anything loose.
    Let me know what you find
  • William Sollows Sep 01, 2013
    no change.
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
Brother MFC-9840 poor print quality.
Hello you can try and fix your problem using the steps suggested below. You may need to clean the corona wire
1. Lookat the corona wire on each toner cartridge. If a corona wire is dirty that maybe the reason that you receive black lines on the pages.Do you have trouble when you receive a fax? If that is the problem look what is cousing it below:
1 Ifyou receive black lines while receiving a fax, the cause of that problem may bedirt in the fax which is sending you the information to you. Advice your senderto clean its fax or to replace the toner cartridge with new.
I hope this can be of any help to you.
May 09, 2012 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW not printing colours properly
Always use Brother toners. This is a common issue with cheap copies and remanufactured cartridges.
Jun 08, 2017 | Brother MFC-9840CDW Laser Printer
When printing with my Brother MFC, the pages are dark.
Did you change the toner cartridge with a new genuine oem cartridge?
Do a report print <settings> page from the menu and check the 'Drum life' Bar graph. If close to, or at 0%, get a new Drum unit
Dec 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
3 black smudge horizontal lines on prints
Your brother can send faxes without printing the pages try your computer just you should download the driver.
You can download the driver from this link: " http://download.cnet.com/Brother-MFC-8220-USB/3000-2118_4-65318.html ".
About the lines which appear on the print, you will have to buy a Drum unit for your Brother 575, because the drum cleaning blade has quit working and there is no other way to fix this only by putting a new drum unit.
note:
the drum unit is different from the toner cartridge, but if you search good you can find them together for lower price.
Please rate me
Jul 15, 2009 | Brother MFC-8220 Fax
Will not print.
What a ditz, it just needed a new ink cartridge.
Jan 23, 2009 | Brother MFC-3340CN All-In-One InkJet...
Incoming fax shows one half of the page
The Thermal printhead is most likely burned out on one side and will need replaced. It could also be the printhead connector has worked loose and is only making partial contact. Remove the connector and reinstall. If that doesn't solve the problem then it would be cheaper to purchase another fax.
Jan 22, 2009 | Sharp UX 108 Roll paper Thermal Fax
BROTHER MFC 425 CN
Power it off!
Then goto start>printers&faxes choose the printer that is printing, in the new box that appears click 'document' then select 'cancel'
Normally if the printer was left on it would continue printing several more pages, as these have already been cached in the memory, switching off the printer for a while clears this.
Are you using fax software? Are you not able to limit the amount of pages to be printed? or at least be able to reject an incoming fax that exceeds a set number of pages?
Aug 11, 2008 | Brother MFC-425CN Multi-Function Center...
Brother MFC 9700
Remove your drum unit and you will see on top of where the drum unit sits inside your machine is a piece of glass(inside the machine). Wipe the glass with a soft dry cloth. If this do not work, remove your toner cartridge and see if the toner is spread evenly on the cartridge.
Mar 17, 2008 | Brother MFC 9700 All-In-One Laser Printer
117 people viewed this question
k24674
jasbo
jasbo
