Question about Onkyo TX-SR605 Receiver
No sound I only have the manuel for the sr705. Picked up this unit as a floor sample.
  • ScottGold Apr 23, 2008
    It turns on. I'm first trying FM. I tune a station. No sound.
  • ALBERT GARCIA
    ALBERT GARCIA May 11, 2010
    does it turn on ? but no sound coming out of it?? or it just dead in the water . let me know
With that particular system, you have to go into setup in order to get the stations to come in.
Posted on Apr 29, 2008
  • 975 Answers
Check for any MUTE button that might be switch to.
Posted on Apr 23, 2008
How do I connect my onkyo tx-sr705 to a pyle pro speaker selector? I am "not" using the onkyo for a surround sound, only for music with 3 pairs of speakers in different rooms. (CD, Sirrus...
Hi Mdensonjr, I see that this was posted in 2011 but well the speaker selector would be connected to the Front speaker terminals, Thanks, JT
May 29, 2011 | Onkyo TX-SR705 Receiver
Picked up a cord, now my floor assembly is vibrating, sounds terrible
i have similar problem, picked up something and it makes terrible noise-hose not clogged- think it is way inside-how do i open it up-or which part do i open up?
the u shaped piece is clear-
thanks for any help at all..
karen
Apr 02, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
TX-SR705 60 hz. Hum
If you have a Home Theater Line conditioner on this receiver, not a power surge protector, even a "Monster" surge suppressor, your problem Is AC related. For troubleshooting; first if your AC power cord is three pronged, go to Lowes, Home Depot, etc. and get a three prong to two prong adapter. Your problem is a "Ground" issue, however it may not be from the receiver, it could be "Anything else" in your home. Even an actual outlet with a loose wire. It can be very very time consuming to "hunt down". An adapter will take the rest of the house out of the picture. Disconnect all other input sources like Cable, DVD, etc. then turn the unit back on. If you still have a humm, yes the problem is internal and needs serviced. If it stops, re-connect one item at a time until the noise re-appears and you have your culpret. If you don't have a line conditioning noise eliminating Theater surge protection unit; Get one! best few hundred bucks you could ever spend. It will protect all your electronics and could save you thousands! Panamax, Furman, Monster, are your top 3. If you still have issues, post a comment and I can help you further. Hope this helps.
Aug 23, 2009 | Onkyo TX-SR705 Receiver
TX-SR705 Hum problem
This a problem of input grounding,the cable input is already loose or crack solder that why you hear a hum or distorted sound because not properly grounded it is a loose contact already thats why also is need to warm up and it will come.First change the cables with a new one with identical size and value then if problem still exist open the back cover ,when open look for the cable input connection parts joints reworks or resolder all soldered joints there .Then checks if it works then cover the unit.If you have no knowledge of electronics dont attempt to open to avoid electric shock.Find a electronics repairman or bring this to a authorized electronics repair shop maybe it cost you only $50.
Good luck;
Dont forget to rate...
Regards:
VOTIT
Jun 29, 2009 | Audio Players & Recorders
Need manuel
The manual for your phone and many other ge phones can be found here
http://www.retrevo.com/samples/GE-Telephone-manuals.html
Dont forget to rate me
May 06, 2009 | Lands Phones
Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
Mar 04, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX SV7M Knocked out by Power Surge
Try pulling the plug out of the wall for 5 min or more,give the unit a chance to reset.Hopefully you didn't get a power surge that might have blown the protection circuits.
Jan 03, 2009 | Onkyo TX-SR705 Receiver
I HAVE A NEW dYNEX tv Model#DXlcd1909
unzip95. Contact MCM Electronics in Centerville, Oh. 1-800-543-4330. Maybe they would send you a users manual.
Nov 19, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Onkyo TX-SR605 Receiver Logo
47 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
