Question about HP DeskJet 3535 InkJet Printer
My printer won't print
Hi
I am having printing problems the ink cartridge is moving when i turn on the printer but the paper would not roll in whenever i send anything to print. The print jobs would just queue up and nothing would print. Help me please
  • 1 more comment
  • Brownskin gi Apr 23, 2008
    Hi Alecz
    Tried that already but that doesn't work......there was a jam and I pulled the paper out and I heard a little click maybe some thing broke or needs alingment...I don't know......
  • Anonymous Aug 03, 2008
    tell me how to intall and set the printer at work.
    printer product name : HP deskjet 3325
  • cgobin_2000 Aug 18, 2008
    Carl here,
    My hp deskjet 3535 printer gave faithful service for 3 years when the both cartridges went low. I replaced filled cartridges and tried to print.but a sheet of paper stuck I removed it from the back and from then on the paper will not feed although the cartridge rack moves normally. I kept trying normally and tenderly.Help please.
    Carl
    cgobin_2000@yahoo.co.uk
Sir,
based on my experienced some posible cause is the the back cover maybe is not properly lock during the pulling of the paper it is opened try to check it. the other one is theres a cracked on the puller assy (the one with spring attached and uses as carriage lock when it moves) check it out!
yours ,
alecz
Posted on Apr 23, 2008
    Problem Solver:
  • 20 Answers
Sir,
I think there is a pending printing jobs on your printer try to cancel all the printing jobs then restart the computer so it will reset all the printing jobs you have. repeat these steps untill its ok. and make sure there is a paper on the paper tray before you do it.
yours,
alecz
  • alexander gregorio Apr 23, 2008
    sir,
    yours ,
    alecz
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
Ink
is it the exact ink replacement or did you have a company refill it ?
Robert
Aug 29, 2008 | Canon PIXMA iP1600 Printer
Printing blank pages
Hi Wendy,
This is known issue with Canon printers. Try the steps below.
Instructions
    • 1
      Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
    • 2
      Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
      • 3
        Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
      • 4
        Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
      • 5
        Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
    Regards,
    Suhail
    May 20, 2012 | Canon PIXMA iP1600 Printer
    My HP Deskjet D1341 has full ink cartridges but won't print. It will print a few words in the middle of a document.
    Hi! Your cartridge head must be block by dried ink. So, remove your cartridge and take some soft paper and rub the head until the color stained fully on your paper... thanks
    Sep 09, 2011 | HP Deskjet D1341 InkJet Printer
    I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
    The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
    The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
    Thus, no BLACK ink reaches the paper.
    Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
    Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
    Ink has run out ??? it no longer prints... TSP100 How do we change the ink roller/cartridge or whatever it requires?
    TSP100 Thermal Printer work with a thermosensible paper, there is no ink to change, if the print quality is poor you have to
    • check the paper roller, it can be wrong installed.
    • Check the upper cover if not closed properly close it.
    • check the print head or the pressor roller.
    Jun 13, 2011 | Star Micronics TSP100 Thermal Printer
    How do you fix a paper feed problem in a Cannon iP1600
    1. Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
    2. Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
    3. Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
    4. Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
    5. Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
    Good Luck!
    Aug 23, 2010 | Canon PIXMA iP1600 Printer
    Canon iP90 stopped printing in BLACK
    hi... it might be that you need some time to let the ink absorb into the pads in the print heads ... this can take between a few hours and a day... Must be frustrating to deep clean three times and just seem that you are wasting ink cartridges, my "solution" would be to give it time or possibly clean the print heads manually.. hope it will solve it out..
    thank u!!
    Feb 10, 2009 | Canon PIXMA iP90 InkJet Printer
    Paper jam problem in pixma mp145. E3 error.
    I have trying resseting and the error message does not clear. I have checked the printer througly and there is no paper jam.
    Nov 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    HP C3180 all in one printer won't realign
    We've encountered several problem like this. Hope this gives an idea; I understand the cartridge will not moved back to park tray or flash ink tray back and forth because the return pick-up guide were not properly placed into each original position. It will block the ink tray moving back and forth. You can roll back the roller into the original place by removing the back cover if it has, then turn the pick-up roller slowly allowing the roller to turn and backed to its original position. Removed also remains of jammed paper pieces.
    Best regards,
    Rosener Guyano
    Nov 29, 2007 | HP Photosmart C3180 All-In-One InkJet...
    110 people viewed this question
    Ben Johnson
