Question about Sharper Image Ionic Breeze GP SI730 Air Purifier
Purple spark and loud noise
I know there is a post about this already but I've tried everything that the previous post solutions has recommended. I've tried cleaning the front and back grill, the metal rods, the two metal strings (corona wire I think). Everytime I place everything back in I can see the spark and hear the noise still. The spark seems to come from the three little metal things that stick out on the bottom of the inside. They are located right under the metal rods. To see them you have take off the front grill and the metal rods. Can anyone help?
  • 1 more comment
  • Anonymous Aug 30, 2008
    Yea having same issue, tried everything other than completly dismantling, which honestly I'm a bit afraid of doing atm.
  • Anonymous Nov 24, 2008
    purple spark can be seen and it's a staticy noise
  • bonwat Dec 29, 2008
    Purple spark & loud noise? Same problem. What is causing this? Is it safe to run?
3 Suggested Answers
SOURCE: my Sharper Image Ionic Breeze GP will not power
as far as I know there are very tiny screws along the sides of the unit. 4-6 screws. remove and make sure to safely put them somewhere and not loose them. good luck.
Posted on Feb 28, 2010
  • 19 Answers
SOURCE: I just took off the front grill of my ionic breeze
no it`s caming that way
Posted on Apr 03, 2010
Bought a 2000 grand am, need to change spark plugs. any help appreciated
Frankie, See how to change the plugs on your Grand AM. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Spark Plug Wires Remove Replace How to Pontiac Grand Am
remove and replace spark plugs
How to change spark plugs on 2000 Grand Am ShopYourWay
List Spark Plug 2000 Pontiac Grand Am Reilly Auto Parts
Jul 11, 2016 | Spectre 2000 Pontiac Grand Am - 2.4L...
Honeywell F50A does not clean well
sounds like it is working. You could replace the cells and prefilters with a disposable box filter that fits.
Sep 23, 2009 | Honeywell (F50F1073) Air Purifier
Loud Clicking Noise
it sounds like an electronic air cleaner, it has a wire feild that kills particles, if somethin gets stuck between those wires it will click. unplug it and see if you can see something, a fuzzball, or lint, something. its trying
Jul 28, 2009 | Brookstone Pure-Ion (506840) Air Purifier
New noise
Hi wendie286,
An electrical hum (for the plasma discharge plates) is normal. If you wind-up the "Purifier" control knob to "max", it will increase, and you'll probably be able to see a faint purple glow coming from th plates. This is normal, and is how the O3/activated oxygen is being produced.
A mechanical hum sounds more like the fan motor. These are the only moving parts and do eventually wear-out. If it's still turning, it shouldn't be a problem - - if it starts turning slower and slower, it's time to plan a replacement motor. I have a couple, but I think FixYa's terms forbid me selling it to you directly. Recommended solutions in this case:
1) If you still know an active dealer, you might see if they have any
2) You could probably find them on the web, though the last time I did this (in December), I couldn't seem to find them; I didn't have a lot of time to spend then.
3) Find another XL15 (maybe on eBay) and cannibalize a fan from the older machine (note: different versions of the XL15 had different motor mounting configurations, so me sure you know what you're getting - maybe ask for a digital picture of the prospective purchase showing how it's mounted).
If you write back with more details, I may be able to offer more precise guidance.
If I can be of further assistance, or if you have questions, let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Jan 18, 2009 | Alpine Air XL-15 Air Purifier
Squeek
Hi Wendie286,
I just answered your other posting which described a low "humming" sound. A squeak is different. Then it's very likely the motor. You could try a _very_ small/light application of oil to the shaft where it goes into the bearings, but that's probably a short-term fix.
If the unit is over 10 years old, the motor will probably need to be replaced at some point. Below is the relevant portion of my response in your other posting.
[fan motors]... are the only moving parts and do eventually wear-out. If it's still turning, it shouldn't be a problem - - if it starts turning slower and slower, it's time to plan a replacement motor. I have a couple, but I think FixYa's terms forbid me selling it to you directly. Recommended solutions in this case:
1) If you still know an active dealer, you might see if they have any, or if they know of a source (Ecoquest no longer supports them with spare parts).
If you write back with more details, I may be able to offer more precise guidance. If you want, I could try web-searching again.
Jon
ALPINE XL15
Hi jackkikay,
A faint buzzing sound is normal - - that's the high-voltage plasma discharge simulating lightning in a thunderstorm. If the room is dark you should be able to see a faint bluish-purple glow of the metal grid on the plate(s) inside. This should somewhat louder as you increase the setting.
It should not really be so loud that is stands out in the background of normal noises (refrigerator running for example). If the buzz is loud - - like something is shorting-out internally (loud crackling sound), that would signal a different problem - - I'd need more details about what you're observing. Approximate purchase day, specific model, number of plates, general condition of the interior would all be helpful if you deem the buzz to be too loud for normal operation.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Oct 29, 2008 | Air Purifiers
Sharper Image Design Ionic Breeze GP Professional Series Mod 1861
My professional series Ionic breeze GP blows out what seems to be clean air but the purple lights inside it are no longer working. Can anyone tell me where I can find replacement bulbs or just what I need to do to get it working again. I got it as a gift 4 or so years ago. The gift giver says there was a 5 year warranty on it but I am not sure. Any advice would be helpful.
thank you. Nicole
Aug 28, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Defect Hybrid GP
I had the same problem with mine, it would start then go into drying mode. I got it to work properly by smacking it around for about a week then it went back to it's lil tricks with drying mode again. After trying just about everything short of using it for target pratice, I made sure it was clean and dry then I turned it to the Medium setting, pressed the power button waited just a second for the fan to go into the meduim fan level, then I pressed the power button again holding it in before it went into the drying cycle, while I held the button, (don't release) I wadded up some tape to keep the button depressed then I put some tape over that to keep it that way. It works perfect! Note, mine never had any crackling issues to begin with, just the drying cycle thing so use this suggestion at your own risk. Good luck!
Jul 24, 2008 | Sharper Image Hybrid GP (SI724) Air...
XL15
The ozone plates need to be cleaned monthly to work effectively. You can get an owner's manual for free from the manufacturer's website, it's at:
http://www.ecoquestintl.com/support/US50300_Living_Air_Owners_Manual.pdf
The manual has a description of the type and frequency of cleaning of various parts of your air purifier. Hope this helps!
Oct 29, 2007 | Alpine Air XL-15 Air Purifier
Ionic breeze is arcing inside unit
I have a sharper image ionic breeze hybrid gp that ran fine for years unitl it recently started sparking / arcing at the base of the grid blades and always in the same spot. I cleaned it several times but the sparking always came back and the unit went into either "drying grid" or "attention required" mode. The solution I found was to stand the removable grid in 2 inches of Pine-Sol cleaner 50/50 diluted with water for 24 hours then brush again with the cleaning brush and hot water. Presto! No more sparking.
Oct 16, 2007 | Sharper Image Ionic Breeze GP SI730 Air...
Sharper Image Ionic Breeze GP SI730 Air Purifier Logo
71 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
