Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
Hp pavilion f1903 flat panel
Black screen, power light blinks amber
  • 4 more comments
  • evanna54 Oct 13, 2008
    a few days ago mine went black with green light still on, so I unplugged it. Next day came back, plugged it back in and it worked for about 15 mins. then went black. What a bummer. If it is just a switch or whatever, I just need to know where to buy the switch and type of solder etc. Thanks
  • Anonymous Dec 02, 2008
    I have the same problem. What's the power cable for the Inverter Board? You mean the monitor cable?
  • willcottrell Dec 19, 2008
    blank screen and the power buttons is flashing amber. Can you get the power supply or the PCB needed? willcottrell@roadrunner.com
    Blank screen and power button flashing amber.
  • nedjari2 Dec 24, 2008
    blank screen and the power buttons still off
  • Anonymous Dec 27, 2008
    yess epic fail.... going to get a new monitor.
The problem is with the inverter board. It is pulling down the main power supply and cycling it on and off (crowbaring). If you disconnect the power supply cable to the board, the power supply will stay up and the power on lamp will cycle as normal. There seems to be a problem with one of the high voltage transformers on the board. I will let you know if I can find a suitable replacement of if there is a way to get an inverter board inexpensively. Good luck!
Posted on Jun 26, 2008
  • 180 Answers
Something to do with the power section.
Posted on Apr 23, 2008
  • 180 Answers
The problem may be with your PC. Chek whether the PC is booting. Can you hear the beep sound. If you can hear the beep sound while booting then the system is OK. So before you trying to repair the monitor confirm the PC is working.
Posted on Apr 24, 2008
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion F1903 flat screen monitor dimmer with grey lines
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
What causes a dark screen and a flashing power button for a HP Pavilion F1903 19" flat screen monitor?
Probably find the screen inverter has failed and needs replacing. Can be a fiddly job as you have to dismantle the monitor so take it to your repair shop if you're not familiar with this type of repair.
Apr 28, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
No picture
Hi
You have parts on the power supply board which are going bad. You can send it to a company like mine or take it to a local repair person.
Aug 05, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1903 monitor
sure the F1903
is a LCD monitor but is old , it has
and CCFL black lamp.
it has board inside that is the power supply /inverter
this board runs the lamps.
the lamps love to fail after 10 long year of service
so when monitor fails, push the menu botton on the front
is the OSD menu dead (monitor brains inside)???
see bottom of this page , see CCFL and PCB there?
if lamps bad replace them
if PCB bad replace it, seen sold on Ebay , vastly, there.
http://pcdied.com/black-screen.html#CCFL-examples
some of these old monitors.
have silly internal sleep mode,
turn that off. (push menu button on front)
see OSD (on screen,display menus)
see settings
see power saver mode, turn it OFF,
Jul 28, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1903 FLAT PANEL POWER PROBLEMS
internal power supply failure in the monitor generally repair is more costly then replacement,that can be verified if you can find a tv repair shop that provides free estimates.
Dec 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Flashing Power Light
When this occurs an inverter, backlight, vga connectiosn, etc could be the cause, my suggestion is connect it to some other device, if you get the same result then your monitor is bad!
Nov 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Going to Sleep
got the same issue
hp pavilion 1723
Nov 01, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
358 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
