Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Lime buildup on Maytag MDB5100AWW
I have a 5 year old dishwasher that is gunked up with lime from hard water. I am wondering if there is a way to remove the bottom sprayer to clean inside of it. I have tried all of the lime cleaners to no avail and am hoping if I can get inside, I can scrape out some of the lime buildup... Right now, it doesn't rinse anything, and I am sick of the dishes piling up. Help!
  • jnetb Nov 19, 2008
    Same problem!  Maytag QuietSeries 400 - my glasses look disgusting!  I would love to hear if you find a solution.  I'm right now, trying the "vinegar in a coffee cup" and run through a wash.  We'll see.  I'm with you, I would like to pull the bottom off and see if it can be cleaned out.
  • 487 Answers
This should give you an indication of how to take it apart.
Please rate me
Posted on Apr 23, 2008
My older model Maytag Jetclean doesn't clean.
The white residue may be lime from the water coming into the house (and, obviously the machine). Run some COLD water into a large clear glass pitcher and let it stand overnight. If there is lime it should settle overnight to the bottom of the pitcher. If no residew, get some commercial dishwasher cleaner and run the machine full hot and on all cycles at least 3 times to thoroughly clean it out...Good luck!
Dec 27, 2012 | Dishwashers
Model MDB5100AWW, sn 10493315YK. Dishes not coming clean, stuck on food, and cloudy. We have installed new Jet Dry, and operated unit in rinse cycle with added vinigar about 4 times with no luck on...
The problem is hard water. has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Oct 03, 2010 | Maytag MDB5100 Dishwasher
Our glasses are really cloudy. How do we clean the inside of the dishwasher?
This may be a hard water issue, but assuming it's not:
Pour 1 liter of white vinager into your dishwasher and run through a full cycle.
If this fails:
Pout 1/2 liter of CLR into you dishwasher and run through 3 full cycles.
N.B. Vinager is preffered as it's non-toxic.
Other possible issues:
hard water, lime/sediment buildup in hot water tank, not using rinse-aids like "jet-dry"
Sep 08, 2009 | Maytag Dishwashers
I have a Maytag MDB dishwasher. We recently took apart the spray arm assembly down to the filter to clean out the lime. The problem is that the inside of the spray arm has such a build up of lime and we...
have you tried boiling it in vinegar? it might help. no garenties for that particular problem, but that's what I do with my kettle and chunks of lime come out when I do.
Jul 18, 2009 | Maytag MDB9600A Jetclean II Built-in...
Thick white coating inside dishwasher and on dishes
That's lime build up.Buy some c.l.r. (calcium,lime,rust) remover from a supermarket.Pour a cup in and run a long cycle,you may have to repeat this until it's gone.
Mar 04, 2009 | Dishwashers
Dishwasher filled with water even though cycle was finished.
the same problem accures with some types of washing machines,when you turn on the machine the control switch sends a signal to a valve on the mains water supply inside the back of your machine telling it to open the problem accours if you live in an area that has hard water because lime scale builds up in this valve so when you switch it off the valve is in the open position because of a lime scale build up, i would say it needs an new valve.adrian
Dec 16, 2008 | Maytag MDB9600A Jetclean II Built-in...
How to clean a Dishwasher of Lime Scale Buildup. Also, how do I read the rest of the teasers at the bottom of this page.
try vinegar
hoiwever you should not have to do this. have you been putting salt in? this is essential in hard water areas
Jun 19, 2008 | Dishwashers
its a lime buildup.go to an industrial cleaning supply wharehouse (maybe home depot-lowes),and get can go to a supermarket and buy c.l.r. (calcium lime remover) but if its real bad you need a stronger delime.simply put the delime in the unit and run it through a may have to do this more then once to get rid of the scale.then once a month use a cup full of delime depending on the hardness of the water.
Aug 26, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
549 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
