Question about Xerox FaxCentre F110 Plain Paper Laser
Fails to work though powered up
With the unit plugged in and powered up the error light is on solid as well the fax in pending light is on solid and on the display screen one of the black segments continuosly flashes with no error code does anyone have any ideas. thanks and hope to haer back soon
  • maureendugua Aug 29, 2008
    I have the same problem. I believe I have tried everything. I would like to know more about memory reset.
  • Andy Wong Feb 23, 2009
    I have exactly the same problem! I'm curious how you have fixed this problem. Is it possible that you or Guru tryit share the possible solution with me? Thank you in advance!
    President:
  • 2,072 Answers
That is due either to memory corruption of a bad main board.
the memory reset is really complicated. If you want to provide me your E-maill address it would ne easier to explane.
Posted on Apr 23, 2008
  • jfo_resare May 17, 2011
    I have the same situation on my F110 (red + green solid ON + binking cursor)....... Is there any way to recover this ? jfo_resare @ hotmail
  • siraris1939 Jul 06, 2011
    having the same issue - hope you guys still have that fix. can you email me the memory reset procedures at: sirkoltiks@yahoo.com. Thanks.
My wireless printer HP Deskjet 3050 J611 is not printing even though the blue light is solid. The yellow light is on. What do I o
clear the print que of all jobs pending reboot the printer and computer your printing from double check in devicers and printers that your printer is set as default and then try again
Jul 12, 2012 | HP Deskjet 3050 All-in-One Printer CH376A...
Error Message: "Unable To Change"
Check for pieces of paper in ADF
any blockage in the unit anywhere
Then, disconnect the MFC from the power
source for several minutes
1. Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
and then reconnect it.
Check that all fax settiings are disabled
and there are no print files pending in
mimory shouldnt be but who knows
Dec 17, 2007 | Brother MFC-5840CN All-In-One InkJet...
When i go to turn the tv on the green light go on and then off. i did the coe test error code repeated 10 times
I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again
Jan 02, 2011 | Mitsubishi WS-55807 TV
When i receive fax my fax says line error
You configure you fax program.Such as line type,fax number,or you follow user manual,how can use it?
It is problem setup or configure not problem machine.
Dec 03, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Phillips magic 5 voice dect fax
phillips magic 5 dect fax showing ''1 pending error''
cant remov e it
Nov 16, 2009 | Philips Office Equipment & Supplies
Pending printing
Printers and faxes then highlight printer then go to file and select set default printer. Then open printers and faxes go to file select restart
Apr 15, 2009 | Office Equipment & Supplies
Paper jam alarm in, but there is no jam.
try to reset the printer or turn it off for 1min and then back on. That should work.
Dec 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Unit can receive faxes but can not send
  1. Press the Fax button on the operator panel and then press Options (once only). The Pending Faxes menu will be displayed.
  2. Press Select. If a fax is pending, the printer will display Cancel Fax (the fax number you dialed appears below these words).
  3. Press Select to delete the pending fax.
  4. In response to the Are you sure? prompt, press 1 for Yes ( 2=No).
  5. Press Options (once only). The Pending Faxes menu will now display None.
Oct 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
IntelliFAX 4750E - Printer Busy
The printers memory may be full depending on the type of documents they are printing. The first and most simple step is to unplug the power cord from the back of the unit for 30 seconds, put your finger on the stop key while plugging the unit back up and continue holding the stop key until the time and date are back on the display of the Brother unit.
If that does not work unplug the USB cable from the PC. Unplug the power cord from the unit again. Put your finger on the menu key first and then plug the unit back up. You want to hold the menu key unit the until the LCD says maintanence and all the lights are flashing. Let the menu key go and press the number 82 and will give you an error code. If the error code is 00 then there are no errors. If there is an error code record it and contact brother or check a service manual if you have one. Most laser products all have the same error codes with Brother.
To reset the unit press stop and then 91, this will reset the unit and all faxes or print jobs will be lost. This should clear the issue.
Jan 02, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFax 4100 sending solid black pages
There are two possible solutions. Is the machine sitting on top of metal? The machine will send black pages when there is static charge. You can put a rubber mat under the machine or use a static guard. The second solution is to put the machine in maintenance and reset the scanner. Unplug the machine, put your finger on the menu key first and then re-plug the line while holding the menu key, in about 30 seconds all the lights will flash and the display will say maintenance. Release the menu Key and press 55 and this will reset the scanner; if scanner error comes up the machine will need to be serviced. Press stop and then 99 this will exit you out of maintenance. If the machine does not have an error try making a copy of blank sheet of paper and see if there is any improvement. As a routine clean the scanner glass with soft lint free cloth and isopropyl alcohol also.
Mar 10, 2006 | Brother IntelliFAX 4100 Laser Fax
Xerox FaxCentre F110 Plain Paper Laser Logo
373 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
