Question about LG VX8300 Cellular Phone
How do I open up the back of the lg phone??
MY PHONE ISNT WORKING. i WAS GOING TO CHECK THE BATTERY AND SUCH, BUT HAVE NO CLUE HOW TO OPEN IT.
Push down exactly on the raised lines (there should be two of them) and slide it down as youre pushing...it should go... if you try to pry it off you will break it.... if you try pushing anywhere else but those lines at the top of the backing, it will not push so make sure you have your finger directly on the double lines.... hope this helps!
Posted on Apr 25, 2008
How do you get a touch screen to work the phone is working but the touch screen isnt
LG has released a line of cellular phones that come equipped with a sleek touch-screen LCD display. Since these screens are high-tech and sensitive, they can be prone to damage or scratches. If the touch screen on your LG is damaged, and you don't have the money to take the device to a service technician, you can open up the phone and replace the touch screen yourself.
1. Turn off your LG and slide the back battery door down and off of the device. Lift the battery out of its compartment and use your Phillips screwdriver to remove the four screws located on each corner of the compartment.
2. Use your fingers to remove the back panel from the phone. The green motherboard will be revealed underneath.
3. Unplug the four ribbon cables that connect at the middle of the motherboard. Unplug the antenna cable in the top-right corner of the board. Lift the motherboard out of the phone housing and set it aside.
4. Use your Phillips screwdriver to remove the two screws located at the top of the phone housing, then separate the back frame from the front housing of the phone.
5. Lift the damaged LCD screen out of the phone housing. Replace it with a brand-new LCD screen (available from your LG retailer or online) and reassemble your phone in the reverse order you took it apart.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | LG Vu CU920 Cellular Phone
It wont even try to turn on im getting a new one but i want to at least get my pictures and contacts back can it be fixed?
YA IT CAN BE FIXED SIR.......the problem may be in battery of your phone. replacing the battery could solve your problem.make sure the pins are dustless because it will short your phone.check with above clues it will surely works.this will fix your problem THANK YOU
Dec 31, 2010 | LG RUMOR Cellular Phone
MY TOUCHSCREEN ISNT WORKING, I TRIED TURNING THE PHONE OFF AND ON, AND ALSO TAKING THE BATTERY OUT AND PUTTING IT BACK IT AND EITHER DID NOT HELP
never think that you can fix the touch screen problem by opening the phone... it can only be done by professionals.... so give your phone to LG... for checking .... they will repair it in good manner...
go to service centre and tell them about the problem you facing... Bcoz there is no cure to fix damaged touch screen...
the only way is Replacing it with the same one.... and dont forget to ask for genuine LG touch screen.....
Dec 10, 2010 | LG Xenon GR500 Cell Phone
I recently sent my LG ENV3 through the washing machine, after following the advice of the Verizon employee I talked to, I took out the battery, opened the phone and put in bag with rice for 3 days. Is now...
The ringer & ******** part might be corroded.
go to a repair shop & let the technician troubleshoot the problem.
The ringer & vibrate might be bad & needs a replacement or the connection is bad.
Dec 15, 2009 | LG enV3 VX9200 Cell Phone
I dropped my LG VIEW in the toilet and everytime i turn it on it says "emergency download". what should i do??
I would take it to your phone service provider...you will probably will have to get a new phone.
Sep 02, 2009 | LG CU400 Cellular Phone
Lg rumor doesnt vibrate
o well all you have to do is go to the store and then they will send you a new one and they will take yours to be looked at and make sure you didnt drop to hard or anything and then they will let you keep the new one and they will take your old one i hope i helped!
Dec 31, 2008 | LG RUMOR Cellular Phone
Screen and touch-pad buttons
1-Check the battery status of u r mobile , charge atleast 6 hours
2-There is problem in display.Than contact LG care center
Nov 08, 2007 | LG KG800 Cellular Phone
Lg chocolate 800 screen replacement instructions
well all you have to do is open up the phone then when you see the screen there should be wire connecting it to the chip just take it out careful as it is fragile and could brake then just take out the screen and replace it with the new onw and you should be done sence there isnt any hardware you have to install
Oct 04, 2007 | LG CHOCOLATE VX8500 Cellular Phone
LG VX8300 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
