E4- alarm out of balance.. method-manually balance clothes in the barrel by hands.E4- alarm out of balance.. method-manually balance clothes in the barrel by hands.
You can't post conmments that contain an email address.
The 4E (4C) error indicates that the washing machine has detected that there is a problem with the water supply. The most common reason for this error is a blocked or kinked water supply hose.
Aug 23, 2021
How do I fix E4 on my washing machine?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
What does E4 mean on a washing machine?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
Feedback
It is the door error, either not close door or the door sensor switch faulty. Open the top panel , you can see the sensor. My washer is the sensor rusted. After I use sandpaper to clean the touch of the sensor switch, it works fine now.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link. Samsung front load washing machine error code e4 Google Search
The Samsung washer error code reads 4E and means problem with the water supply. Please check the water pressure, also check for blocked or kinked water supply hose. You can learn more about all Samsung washing machine error codes in this helpful article: https://www.justfixed.co.uk/samsung-washing-machine-error-codes/
look in your manual if you have it. also there should be a schematic inside the washer probably with the codes in it. this is mainly sold in Australia so I dont have a way to know.
A code of E4 means that there is to much suds or the pump is blocked. use less detergent and get detergent with he in the title. turn to off and try to restart the drain to correct problem.
You will find the code in the manual. If you do not have let me know I will send you one here.
