Question about Frigidaire CWS3600AS Top Load Washer
Bimmis repair one washer seal attatches to the tub but I dont know where the other flat seal goes and dont understand the description of how that seal faces
    Genius:
  • 1,073 Answers
The small seal set on top of the large seal in the tub, lubercate the seal with some dish washing liquid and slide it down the agaitator shaft the brass side goes facing down
Posted on Apr 23, 2008
My Kenmore front loading washer sounds like a airplane taking off when it is in a spin cycle, is it supposed to sound like that. They are only two years old!!
I can't tell you how many times a year I have that description about a front load washer.
I always find the same problem with them too. The tub seals has let water get into the rear drum bearing making the bearing fail.
Remove the back washer panel and look at the center of the tub. You will often see little trail of grease and water residue from the seal leaking.
If you do not have a extended warranty it's can be a costly repair as you can not just replace the rear bearing. You will need to replace the outer tub that come with the bearing pre installed and often the spinner shaft too.
How to receive the best washing machine repair help on FixYa
Aug 03, 2011 | Kenmore Front Load Washer
I am trying to figure out which way the red rubber sealing gasket should be placed. This gasket goes on the bottom of the tank.
If your talking about a toilet if its flat it goes on the inside of the tank.If your talking about a bath tub the washer goes on the underside of tub drain
May 07, 2011 | Home
Sudsy water is leaking from the machine
Hello there and thank you for choosing fixya
The tub seal is the most common thing that causes Maytag washers to leak. This is unfortunate because the tub seal is an expensive repair job and not one I would suggest doing yourself. I say this because it is complicated and requires special tools to perform this job. To check if the tub seal is bad, first remove the front panel by removing the two screws from the bottom of the front panel. If you have a newer model, prize the bottom clips with a screwdriver. Then pull the bottom of the panel until the top clips release. Then start the washer and watch for a leak around transmission where it goes through the tub. If it does leak then the tub seal is bad and needs replacing. If you have the tool or willing to buy it click here for instructions on how to replace the tub seal. If the tub seal doesn't, leak you probably found the leak while performing this test.
Mar 07, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Change door seal on wjs 1265w
Hi, Your new door seal will have a double lip seal? If you use a small amount of washing up liquid on the lip of the double seal this will then allow you to ease the door seal on really easy. The spring then goes on the outer part of the seal in the groove to hold it onto the tub. Becareful and make sure you put the door seal on the right way up or you will not be happy with the result! TORN CLOTHES!
Good luck...
Dec 05, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
GE WBXR2060V1WW leak_transmission shaft and tub
The tub seal is leaking, often this damages the transmission. A new tub seal comes with the transmission this page should help http://www.appliance-repair-it.com/GE-washer-disassembly.html
Nov 12, 2008 | GE WDSR2080D Top Load Washer
I think my pump is leaking
This can be very simple problem to diagnose and repair. You will need to remove the exterior cabinet in order to inspect the interior of the washer thoroughly. The following link explains how:
http://www.fixya.com/support/r397092-replacing_water_pump
I know the link explains how to replace the pump (that may or may not be your problem), but the steps to remove the cabinet are the same. If the pump is leaking it is NOT repairable. These are sealed units. Make sure all the hose clamps are snug and not leaking as well. If the washer is leaking under the wash tub (in the center near transmission) this is more than likely your tub seal. This is also a very repairable problem with some guidance. Let me know what you find and what your intentions are. I hope this helps you.
Oct 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Ok final Question
If this is a frigidaire, when the washer has a load in it, as the agitator agitates the tub should move about 1/8 of a turn. Meaning that for 8 agitations the tub should make 1 revolution. We call this indexing in the appliance repair world. If the tub is making 1 revolution in 4 agatations or 1 revolution in 1 agitation, the transmission is bad. This should have a 5 year warranty if purchased before 2006. You will also need a tub seal. Hope this helps
Feb 13, 2008 | Frigidaire FEX831CS Top Load Stacked...
Maytag MAV7200 Washer......needs seal and bearing kit
I HAD TO REPLACE THE SPIN BEARING ON MY MAYTAG ATLANTIS WASHER MAV9750,
it was making a loud noise during sin cycle, like a bad bearing would
make, jet engine kind of noise, i did replace the bearing and made a web
site with pictures on how to do it, since it almost takes all the parts
out, it will show you how to get to most of the parts in the machine, and
i also included links for downloading the repair manual, and parts at
appliance parts pros web site
http://maytagwasherrepair.googlepages.com/index.html
Feb 06, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Oasis washer
remove the agitator, then remove the flat steel nut near the bottom. the tub should come right out. you'll need to get a new seal for the tub.
Jun 07, 2007 | Kenmore Oasis HE 27062 Top Load Washer
Frigidaire CWS3600AS Top Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
