When I want to copy a page it cuts off about 1 inch on th e side Have tried everything I put it on the glass like it says and no luck
    Problem Solver:
  • 20 Answers
I think all printer with copier have in common in regard with copying the have all allowance i think its half an inch so if you copy a borderless document its not 100percent copied theres a cut on the side. My solution? scan and edit so you can have a complete picture without a cut.
yours,
alecz
Posted on Apr 23, 2008
I have a Gestetner copier. When I make a copy, there are lines on the right side of the copier. The lines are not solid-except for one. There are 8 lines. It covers about 1/4 of the page. The lines...
Try to make a copy on the copy board glass are the lines there? If not, make a copy using the adf, if they are there you need to clean the smaller , thinner piece of glass to the right side of the copy board glass. Good Luck
Sep 06, 2013 | Gestetner DSm725 Color Copier
Xerox Copycentre C20: Copier doesn't scan top 1-3 inches of page. Happens intermittently. When this happens, it moves everything else on page to the top of the copy, cutting out what should be
The document feed rollers may be dirty/worn which is causing the paper to come into the scan area late causing your document cut offs. use a clean, lint-free cloth dampened (not moist) with water and clean the document feed rollers. Confirm they are dry then, try scanning multiple pages and see if they pull through without stalling. If they do, it's time to replace those rollers.
Aug 27, 2017 | Xerox CopyCentre C20 Black and White...
Hp inkjet printing solid black page
Hi Robert, if you're trying to copy something that you've placed on the glass without closing the cover of the copier, there's too much back light (coming from behind the item to be copied) and therefore the resulting page will be black. The only light should come from within the copier itself.
If the item you're copying is bulky and will not allow the cover to close, try taking an 8-1/2 x 11 inch piece of paper and cutting out only enough of the page to allow your item (to be copied) to sit flat on the glass while covering the remaining exposed glass with the paper.
I hope this helps, good luck.
Jul 16, 2012 | HP Office Equipment & Supplies
I have a black line down copied pages. Printed pages look fine. Problem is only on copies.
Clean the **** glass on the left side where u put the copies on the glass!Good Luck!
Apr 08, 2010 | Samsung SCX-4725FN All-In-One Laser...
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Aficio 1015 Ricoh copier;page margins changed without instructio
Check the print/copying area to see if those controls have been handled or not. Also remove the wire mesh through which the toner passes through. Clean it well but very gently using a painting brush and a blower. Rest it and try a copy....................sodeep
May 04, 2009 | Office Equipment & Supplies
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
102 people viewed this question
k24674
jasbo
jasbo
