Question about HP PSC 950 All-In-One InkJet Printer
Machine does not recognize refilled office max cartridge (black)
I refilled an office max cartridge which was in the machine, after refilling and putting it back into the printer, my orange copy light is flashing, and the message says check black ink cartridge. I have removed the cartridge and reinstalled it, ran the maintainence check, the printer works fine, however the flashing light continues. help!
  • tmmullenheve Apr 05, 2009
    My cartridge is newly filled, the cellophane is removed, and all the connection points are cleaned, but I have the same problem.
  • Anonymous Apr 23, 2009
    I think Office Max has changed their supplier or something. I have used their ink for a long time and now I have started having problems. The last 3 times my printer will not recognize the cartridge, and says it is the wrong cartridge for my printer. It's not. It's the same one I have always used. I don't know what's up but they are going back. Again.
    Problem Solver:
  • 20 Answers
Sir,
try to clean the cartridge on the copper side with tissue with and alcohol maybe the contact points doesnt meet or the cartidge itself is already defective. try also use an empty good cartridge just to to determine wich cartridge is defective.
yours,
alecz
Posted on Apr 23, 2008
I replaced my black ink cartridge with a refilled from office max and it will not print in black. Why?
Most HP cartridges have what's called an ACCUM chip, which doesn't care about the actual ink level, it counts how many milliliters (or droplets) have gone through the head to determine when it's "empty" and therefore refilling doesn't do anything, the accum still says the cartridge is empty.
Mar 05, 2011 | HP Photosmart 2610 All-In-One InkJet...
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
Black and color cartridges refilled. originals back in printer...printer says no color cartridge installed.. have cleaned contacts on cartridge and machine, NO difference. can we print just in black if...
You need to have both black and color cartridges installed with functioning electronics to use your printer. Sounds like your original color cartridge and the refilled color cartridge you purchased both have bad electronics. I recommend Cartridge World or Office Depot for cartridge refills because they electrically screen their cartridges before selling them. You need to buy either a new or refilled color cartridge for your printer to work.
Feb 09, 2010 | HP PSC 950 All-In-One InkJet Printer
Did a black print cartridge refill at Costco. It
You used one of the worst refill services available. There's a reason they have a flat rate for refills, they use non cartridge specific inks, don't clean out the cartridge, and have a machine not a person do the thinking and the work for them. You will have similar failure on cartridges refilled by Walgreens, Office Max, and cheap online refills. I suggest Cartridge World first then Office Depot for refills. They have high quality standards and recycle your cartridges by refilling them.
Dec 18, 2009 | HP Photosmart 2610 All-In-One InkJet...
818 cartridge refilling
If you mean the HP DeskJet F380 cartridges (the HP 21 and HP 22 cartridges) you will have unreliable success refilling these cartridges either yourself or online, at Costco, Office Max, and Walgreens. These refillers generally don't have fantastic quality control or knowledge of printer cartridges. I suggest Cartridge World or Office Depot refills. If you mean the HP Photosmart C8180 (the HP 02 cartridges) refilling them is easy but you need to replace the chip on the cartridge for it to work in your printer. As long as a refilled cartridge has a new chip it should work in your machine. Again I recommend Cartridge World or Office Depot refills.
Nov 24, 2009 | HP DeskJet F380 All-In-One Printer
Overpriced cartridges
Lexmark printers are notorious for over-inking. Probably the most efficient inkjet printer I've owned is an HP (any HP inkjet model). What has become quite popular as of late are refill machines at the local office supply stores. I have my cartridges refilled for less than half the price of new cartridges. Staples and Office Max both have great refill machines, and often have a reserve of pre-refilled (recucled) cartridges that they sell. I do not know your region, but most of the larger office supply stores have these great machines.
Also, if you color print on regular paper a lot, the ink soaks (bleeds) into the paper fibre and tends to waste a lot of ink. If you do not have a largfe office supply store near you, you can purchase refill kits and refill them yourself.(which can be messy, but effective).
Hope this helps.
Jul 09, 2009 | Lexmark X3550 All-In-One Printer
Reset the ink memory level after replacing cartridge
Have you tried to unplug your printer and plug it back in?
May 31, 2009 | Dell 962 Photo All-In-One InkJet Printer
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
Apr 30, 2009 | Dell 962 Photo All-In-One InkJet Printer
Lexmark x5470
Let the ink settle in the cartridge for awhile. Make sure no ink is on the outside of the cartridge which adversely effects the signal to the printer.
Apr 14, 2009 | Dell Dimension 4500 + Lexmark Z35 Printer...
Refill
Hai
Well u can refill the toner,to refill the toner u should contact the nearby service station to refill.
Sep 09, 2008 | Xerox Black Toner Cartridge 25000 Page...
HP PSC 950 All-In-One InkJet Printer Logo
804 people viewed this question
Seeker5211
Seeker5211
