Question about Clarion M475 CD Player
Volume control I have a clarion M475 marine unit. I have added 2 speakers making a total of 4 speakers connected. The volume output is lower now than it was with 2. How do I correct this? I have hooked up my Clarion in conjunction with four inside speakers and four outside speakers on my holiday trailer. Only four speakers are tied together at one time. The radio worked good to start, but one of my kids turned up the volume and now "AMP GRD" is displayed. I turned down the volume and cut the power for 5 minutes, but the display will,not go away. I live in Canada and received this off E-Bay a month ago, but really don't want to ship it away if I can help it. Do you have any suggestions??? I really would appricate any help! Thanks Boyd
  • 1 more comment
  • bjamison Apr 26, 2008
    The speqakers are Sony 8 ohms and there are two speakers hooked in parallel to the front right side and two hooked in parallel to the front left side. These are for the outside speakers. There is a switch to change them to the livingroom and bedroom speakers. The grounds are all connected commomly. With the positive side of the speakers disconnected, I still can't get the "GRD AMP" display to go away. Any sugesstions??
    Is there any way to get the "GRD AMP" display to go away and the system to reset??
    I have the speakers shut off on the positive side.
    I hooked up a receiver to the same speakers, and all the speakers work fine. How do I get the "GRD AMP" display to go away now that I have the positive side of the speakers disconnecdted??
  • 975 Answers
IT DEPENDS how you connected the 4 speakers system to this CLARION unit . if each spkr is 8 ohms VALUE , connecting it in SERIES will add to 32 OHMS resistance , that means that CLARION unit will lower the audio output . but if spkr are connected in PARALLEL It will lower the resistance and giving you more power to speakers. this SOLUTION for the speaker connections only . hope its helpful.
Posted on Apr 23, 2008
  • 373 Answers
AMP GRD means that the Amp is grounded which probably means a short to ground and could be the audio output circuit to ground
  • TV Doctor
    TV Doctor Apr 23, 2008
    Especially since the volume was turned up all the way....overloaded the audio amp and shorted it out.
  • TV Doctor
    ginko could be right but, if you didn't use the proper ohm speakers and the volume up all the way its likely to short audio circuit.
  • Clarion Master
  • 19,396 Answers
  • Ginko
    Ginko Apr 23, 2008
    Amp grd is amp guard error, you have a short in your wiring to speaker. Get new wires and re wire speakers, and it go away
Have clarion cz200 receiver hooked it up it powers up and everything just fine but no audio...checked everything and it seems fine but no audio am i missing something? its in a 1981 chevrolet c10 pick up
With this particular unit you have a Tele mute which is cell phone related to mute volume when your cell phone rings if this is grounded then you have a problem.
1) Verify that the speakers of the vehicle are correctly hooked up , you can test your speakers by taking a 9 volt battery and touching the positive and negative leads of the speaker wires (make sure they are disconnected for radio) you should hear a click.
2) Take a volt/ohm meter set it to ohms touch the leads together this is continuity. Next touch the wire leading to the speaker to be tested and place the other lead of the meter to the bare metal of truck. If the needle pegs all the way over you have a shorted wire.
3) If using a seperate amp to power the speakers you need to insure that all connection to the amp are made properly and grounds are correct.
here is a link to clarions website to provide a troubleshooting manual.
http://www.clarion.com/us/en/MungoBlobs/341/106/CZ200_EN.pdf
One other thing to check is the center channel balance as if it is biased you need to adjust it.
There are only a few simple things that can cause no audio output
1) Volume not correct
2) Audio output connections incorrect
3) Speaker wires are bad
4) damaged speakers
5) tele mute is grounded
6)Speaker wires insulation is cut and grounding out or is not making a good connection
7) worst case Radio is defective ( it happens)
Mar 08, 2011 | Clarion CZ200 Car CD USB MP3 Player
In my boat is a Clarion CMD6 head unit with two rear CMQ1620R speakers, it distorts at medium to high volume, you cant turn it up load when going.Wishing to put two new speakers in the front, cannot cut...
Best bet is to take your boat to a qualified Marine Audio dealer (generally not a boat repair shop or marina), or to a good quality Car audio store that is insured to work on boats (separete insurance usually).
When it comes to boats, you need lots of power and speakers.
First thing to do is make sure what you have is properly installed. Then determine what is "distorting" .. is it too much base, purely volume or what.
Most boats we do (wakeboard style and river boats) we do: 40-75 watts RMS per speaker 4-6 speakers in boat 1 10" or 12" sub with 200-300 watts RMS Tower speaker if requested with 75-125 Watts RMS per speaker
Feb 06, 2011 | Clarion Car Audio & Video
CMV1 is not working. When I press power button the
Check your grounds, you may have a bad ground connection behind the radio in the harness or your marine battery is having a ground issue, check that out first if that checks out ok then check out your speaker connections and make sure that they are wired ok. My experience with speaker thumps and pops has to do with ground.
Good luck.
Jun 19, 2010 | Clarion M255 AM/FM Marine CD Player
Speakers Crack at mid to high volume (anything over level 20)
make sure speakers are connected properly to individual speaker outputs from radio .Also make sure speaker cables going to speakers are not pinched or shorted anywhere
Jul 30, 2009 | Jensen CD400M CD Player
Volume issues with clarion M309 installed on a boat
Hello jcox7704,
Your head unit is 50 watts X 4 channel maximum power and 21 watts RMS so it's possible that all you need is more power to the speakers. But even 21 watts RMS should be enough for normal speakers. Before investing in an amp, I'd check the speakers and their wiring. Measure the impedance (resistance) at the head unit side to see if they match up.
Hope this helps.
Jul 02, 2009 | Clarion M475 CD Player
Power goes on and off-flickers
That is most likely because the radio is drawing more power than the wire can provide. First make sure you have good connections, especially a good clean ground. Next make sure the power wire from the boat is at least the same size or thickness as the power wire on the radio. If that doesnt work, you may want to wire the radio directly to the battery, using an aftermarket inline fuse and wire available at any car audio store.
May 24, 2009 | Clarion M475 CD Player
Sub woofer volume adjustment
The gain dial is not a volume control. The gain dial is used to compensate the output level of your car radio head unit. all car stereo units output are not alike. If you set this gain level too high, it will cause major distortion (clipping) to the audio output of you speakers when cranked up. This excessive distortion WILL eventually, or even quickly damage or blow your speakers.
I personally blown speakers this way no not properly setting this. (lesson learned, I guess :| )
Jan 27, 2009 | Clarion DXZ545MP CD Player
When volume is turned up the radio shuts off
Have you checked all of the connections on the speakers, stereo, etc. Being a marine CD player, the wires and connectors are exposed to more elements than a car CD unit. Check for corrosion and make sure that all the speakers are hooked up to the correct "+" and "-" terminals. Not sure if this will help, but thought I'd try. It does sound like a speaker connection problem.
Aug 30, 2008 | Clarion M255 AM/FM Marine CD Player
Clarion M475 CD Player Logo
435 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
