HP HP Pavilion dv6000z 15.4" Notebook Laptop PC  PC Notebook
Problem for HP HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD...
Wont Recognize DVD drive
By EagleTwo on Apr 23, 2008
I have a brand new laptop and my problem is when you insert a cd/dvd nothing happens. Iv'e tried to update the driver and it says its already updated. When I click Computer under the start menu It doesnt even Show I have any other drives than my C drive. When I go to the Device Manager and right click the DVD drive, Go to Properties and Message in the box says Windows cannot load the device driver for this hardware. The driver may be currpt of missing. (code39). It says check for solutions and I click that but nothing happens! ???
Same Problem
Nov 22, 2008
-   I HAVE ACER DESKTOP BUT SAME PROBLEM
-   nishan1947
May 03, 2008
-   My problem is exactly the same except I get a Code 10 error condition
"This device cannot start. (Code 10)"
thomas.p.jones.jr@gmail.com-   tj0nes
Best Solution
posted on Sep 18, 2008
Very Helpful)
hardkiss69
Rank: Wiz
Rating: 92%, 83 votes
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver fro this hardware. The driver may be corrupted or missing (code39)".
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on May 06, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
hey, i have exactly the same problem, i need some help on this! it has something to do with its drivers. the error code is 39
Solution #3
posted on Apr 23, 2008
Not Rated)
3rdPartyTech
Rank: Guru
Rating: 87%, 66 votes
I have heard of this happening on newer computers and laptops using windows vista. If this is the case, I would contact your computer manufacturer and explain what is happening. If your computer truly is "New" it should be under even a 1 yr manufacturer warranty. There is a possibility that they are already aware of the problem and have a way to fix it.
Was this helpful?
Yes
No
Popular Solutions for HP HP Pavilion dv6000z 15.4"
Questions and Unsolved Problems for HP HP Pavilion dv6000z 15.4"
Do you recommend HP HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook?
Answer
Answer
My laptop seems to be tweaking out. whenever i click something it will click it more than once. also... (More)
Answer
i have a built in web cam what wont turn on can u help? its an hp Pavilion dv6000 and when i try to... (More)
Answer
I have a sparten lap top--trying to use web cam via skype-it wont rec. the web cam-(used to but wont... (More)
Answer
My AMD-8151 Hyper Transport (tom) AGP 3.0 Graphics Tunnel also doesn't work properly because Windows... (More)
Answer
how to switch HP notebook dvd player primary display to TV monitor -
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
