New Samsung monitor, Syncmaster 2043BWX randomly goes completely black for about one second and then flashes back on. I have a new replacement that is doing the same thing. My video card is Nvidia NX7300LE, I'm using the digital output.
2 Suggested Answers
alocenar
  • 293 Answers
SOURCE: I just bought a new
did you try to use this monitor in another pc? if its doing the same thing, you probably have a defective monitor.
Posted on Apr 17, 2008
Samsung syncmaster 172v Screen goes black after about one second. Comes back to normal after turned off, but goes black again in about one second. Rebooting computer has not fixed this.
Sorry it is like your monitor needs service. Electrolytic condensators in power supply need to be changed. Give it to an electronic shop, it is a job for a specialist.
Oct 18, 2010 | Samsung SyncMaster...
Samsung syncmaster 930b 19inch: blinking green light on startup screen does not respond turn off or on after a random time period it usually works once screen goes from black to windows it stays...
<P>If you try new cable, try with another PC and still have the same problem, then you need to inspect the inside for bad caps first just like all the SAMSUNG as shown.</P><P style="tab-stops: center 3.25in left 255.75pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://s807.photobucket.com/home/budm/allalbums"><FONT color=#800080>http://s807.photobucket.com/home/budm/allalbums</FONT></A><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</A><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <A href="http://lcdalternatives.auctivacommerce.com/Viewsonic-C196320.aspx"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>http://lcdalternatives.auctivacommerce.com/</A><SPAN style="mso-spacerun: yes">&nbsp; </SPAN>he can make you a set of caps for you.<o:p></o:p></SPAN></P><P>&nbsp;</P>
Aug 25, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Monitor will flash the display for a second then go black again.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Apr 12, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
I have a samsung Syncmaster 2343 and I can turn it on just fine and my computer recognizes that it's hooked to a moniter but the moniter shows the screen for a few seconds and then it all goes black. It's...
If your up to opening the monitor it would do you well to look. It sounds close to what I experienced.Refer to Problems with Samsung SyncMaster 2053bw for info on opening.
Nov 11, 2009 | Computers & Internet
Flashing screen when i first turn on my SamsungSyncMaster 2232 bw
I had a similar problem with my LCD computer screen. I took it apart and noticed a capacitor that was raised up on the flat end and appeared to be leaking a substance. Replaced it with a similar capacitor and works fine, for three years now.
Jul 05, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Samsung monitor randomly flashes black
> brand-new out-of-the-box
Presumably, it has a "warranty".
So, take it back to where you bought it, and demonstrate the problem to them, and make them repair/replace it, under warranty.
Sep 21, 2007 | Samsung SyncMaster 214T Monitor
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
