Question about Philips 50P8341 50" Rear Projection Television
My TV has a yellow green picture
The color on my TV looks yellowish green. Are there bulbs or something you need to change to correct the colors?
SOURCE:
  • 4 Answers
SOURCE: picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Posted on Apr 28, 2008
Slinteriors
  • 8617 Answers
SOURCE: phillis 55pw9363 yellowish - greenish picture
cleaning the CRT lenses and mirror will help, however with that model I would suspect that the gree and blue CRT needs the coolanr changed to get a your color and clarity back. thats a common problem with all phillips rear projection TVs
Posted on Jun 13, 2008
premtech
  • 934 Answers
SOURCE: no picture and i replaced the bulb
Joe,
I've never heard of a color wheel costing that much even with labor included - I think I'd try to find another tech for his advice.. If you have trouble locating one try NESDA or let me know what city/state you're in and maybe I can help recommend someone.
That said, if the lamp is good the next logical thing to check is the ballast. If the ballast is not supplying voltage to the lamp then it clearly won't light. A ballast is not that expensive, similar to a ballast in a floresent light - only a bit more complex. In any event I would strongly suggest finding a real professional first we are out there...
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
[email protected]
Posted on Dec 02, 2008
  • 2920 Answers
SOURCE: bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Posted on Dec 28, 2008
Ecollier2012
  • 3459 Answers
SOURCE: TV Picture is distorted
1) Convergence chips are shorted....One quick test is to desolder and remove both STK392 chips....then power the set on. If the tubes light up the chips were shorted. You can get new ones from www.TvRepairKits.com
2) Another possible problem is a bad HVG - AKA the flyback.
Try the convergence chip test first. Note: On some Philips sets you can just unplug cable "1516" instead of removing the chips.
For instructions on how to find/remove cable 1516 visit the website listed above and click on their tips page. On that page click on the "Magnavox DPTV3xxx Checks" link.
Posted on Feb 13, 2009
I have the Sony KDS- 60A2020 60 inch TV. Recently, my picture has appeared more yellowish. Everyone on it looks like there dark yellowish or have fairly dark (bronze) sun tans. I changed my lamp yesterday...
I have a older 2006 SXRD rear projection TV. I had the same problem after the TV warmed up this yellow tint started in the corner and crawled its way down the TV. It turned out that Sony had a recall on the optic block of the TV. If you replaced the Lamp and adjusted the color this kinda sounds like the same problem. Here is a link explaining it. In this article it shows up as a green haze and blob, but in my TV it manifested as a yellow tint.
http://www.avsforum.com/avs-vb/showthread.php?t=1086180
Jun 09, 2011 | Sony KDS-60A2020 60" HDTV
Hello, I have a 2005 Sony KP-51WS520 Rear Projection TV. Recently, the green colors all become a yellowish/orangish color. When you are watching a baseball game the grass is a orangish color. ...
DLP tvs have a design weakness,the problems it is call a convergence problems,it is dead.This convergence problems,will have happen many times through out the tv live.The tv have a colors R,G,B lines misalignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv board,that call the tv convergence board it is dead.The tv convergence board,must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv colors picture convergencce problems.The tvs shops will cost u like $300-350 for parts and labors.
May 24, 2011 | Sony KP-51WS520 51" Rear Projection...
I have a Nikon Coolpix L110. When I take pictures, they often look yellow. I can get the color to correct by focusing on a nearby area, but when I return to the shot I want to take, the color almost always...
Try resetting the white balance. Colors will change according to light source( temperature of light.) most cameras will have an option for light type. If you are using artificial light, note the color temperature of the bulb.
Aug 05, 2017 | Nikon Coolpix L110 Digital Camera
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
I have a yellowish tint in the center of picture
Why does my picture appear yellowish on the screen? I haven't changed the bulb in at least 2 years. Does this make a difference?
Aug 11, 2009 | Epson - PowerLite S1+ Multimedia Projector
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Mar 11, 2009 | Panasonic PT-50LC14 50" Rear Projection...
I have a hitachi ultravision tv m#53sbx10b s#v1g000279 and everything works but there is a blue and somtimes yellow swoosh thing in the top left corner. it like fades throughout the colors? i was hoping...
Your Green CRTs coolant may be congealed giving the green tube a yellowish look it should be a vibrant green. Try changing the coolant in the CRT
May 06, 2008 | Televison & Video
Sanyo 5.0 megpi( yellow tint)
yellowish color is due to the light your flash gives when taking pictures. i suggest you bring that to a service center and let them take a look at your camera...probably needs a bulb replacement.
Jan 26, 2008 | Sanyo Xacti DSC-S4 / VPC-S4 Digital Camera
Yellowish color
turn off the color and see if you have a good grey picture if not your grey scale is off and requires adjustment
Aug 26, 2007 | Hitachi 43F300 43" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
360 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
