Mitsubishi vs45607 dead
When I press power only a click,and nothing more thank. Mitsubishi VS4551a I turn on the power and all I hear is a click...no light no nothing....Help!
  • JPMac Apr 23, 2008
    This is a rear projection (Mitsubishi VS4551A)...I see no leakage and all the fuses seem ok. The only problem I've ever had with this TV was that the fuse closest to the power inlet blew out, I replaced it and it worked fine...that was probably 7-9 years ago.
  • 8,617 Answers
Un plug the set and use a flashlight and look for evidence of the CRts leaking on the chassis this is a common fault with that model. It will cause a dead set.
Posted on Apr 23, 2008
  • Sonny Berry
    Sonny Berry Apr 24, 2008
    ok the next thing to do is check the low voltage regulators and the horizontal output. thats usually the first thing that i try. Also have you tried pushing in the menu and input buttons on the set in together and hold them in for 8 secondes to see if the LED will blink an error code? Also do you have a service manual for your set?
My mitsubishi 55" will not turn on... when I press
Hi:
The most common failure for this model is the deflection board assembly or commonly known as a Large Signal board. The unit is going into shutdown, mode because no high voltage. Unless you are strongly electronically inclined I suggest you try to replace the deflection board.
Nov 10, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi VS45607 tv
Brief an d to the source. A high voltage speed switch is bad and we will cross reference it with an NTE 2361. But this is only the start. You can crossreference all of the transistors. Q531,Q532,Q533 Q530 , Q5ADO [Horizontal output transistor] and Q5A02 Looks like Q502 on board [also i think this is also an horizontal output transistor. Then by all means change the following capsC541, C551, C531, C562, C534, C402, an d C933 . It will take some time to do this, be patient my friend. Your Mishis will return!
Jun 13, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-6041 60 in. doesn't power up
Hello Tremulant
This denotes a possible problem with the Low or high voltage power supplies. The clicking you here might be the shutdown circuit acting because of excessive draw of current. The problem will most likely be associated with the HV power supply, but you will have to have a qualified TV technician check your TV to make sure.
I hope this helps,
Thank you,
Shuttle83
May 31, 2008 | Mitsubishi VS-6041 60" Rear Projection...
Check for leaky D980 PART # 264P045040. You also can try to do a self test to get the error codes, search here or on ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi Power Problem -turns itself off.
Sounds like CRT coolant leak onto signal board = check
for work....................................................T.
Nov 10, 2007 | Mitsubishi WS-48613 48" Rear Projection...
This denotes a problem in the HV power supply and the shutdown circuit shutting down the Tv to prevent damage from a component that is drawing too much current. I would suggest that you have a repair person look at your TV and give you an estimate.
Sep 20, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs-5052 tv
as you are not electronic person so call skilled person. problem is simple. 1 there might be in power supply. 2 if power supply is ok horizontal section might be defective
Sep 16, 2007 | Mitsubishi WS-65615 65" TV
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
Electro Med Services...
