Question about Fostex MR16HD/CD Digital Recorder
The click that I orginally recorded to has changed????
Has anyone an antidote for this issue? I recorded mulitple tracks using the tempo setting on the rythym guide, ,but when I shut down and go back to the track, the click has changed. Help!
If you have prgm save; make sure you store the settings before you shut down or the program with revert to default settings.
Posted on Oct 31, 2012
Hi folks :-) I'm affraid that we have started up wrong, but I hope we can fix it ! Problem: A band, we've made a que-track (everybody's playing and singing at the same time) now we've...
Real musicians do change tempo throughout a song, so its not necessarily a bad thing. As long as you like the sound it doesn't matter if you don't stick rigidly to a fixed tempo. Unfortunately you won't be able to fix the tempo after the initial recording so you'll have to live with it or re-record. If you need a click track to record along to, try recording yourself hitting drum stick together along to the already recorded track. As a human you can track small tempo changes much easier than a computer. If you need to create a count in, just copy and paste a section of this click track to the start of the track. I hope this makes sense!
Sep 20, 2011 | Tascam 2488 Portastudio Multitrack...
There is a delay with the sound I play it but the green light is,nt in sync the same time I play its a little bit delayed.
The green light is NOT a tempo light and will not be in sync with applied audio. If you need a tempo indicator, turn on a click track in your computer or use a metronome.
Jan 31, 2011 | Lexicon Alpha Personal Recording Studio
The click track on my TASCAM 2488 Mk 2 won't click
There is likely an amplitude setting (probably available in a menu) for the click. Make sure that is turned up.
Jul 18, 2009 | Tascam 2488mkii 24 Track Recording...
Trouble with hooking mpc4k and korg triton pro to mbox
you will want your triton midi-in to go to your mpc midi-outB
then your mpc midi-inA to go to your mbox
your mpc midi-outA to go to your mbox
that should get you good for midi cables....
on the mpc, everytime you want to record a track using instruments from your mpc you will need to set a new track. on the main screen you would go to a new track (where Tr:01-Track-01 is) and change S:DRUM1 to S:MIDI, then to the right of that where it says OFF, turn that to 1A-Device01 ... you will have to make a new track for each instrument you use to help when bouncing tracks to mbox. for instance 1A-Device01 is the 1st track on your triton, 2A-Device02 is your second track and so on. make sure you also make a new track each time for where Tr:01-Track-01 is also for each instrument.
for the mbox i might be a little rusty on this so im going to post a quote from another site....
"in Pro Tools, go to setup - midi - midi studio. this is where you tell pro tools where your midi devices are connected. next, go to setup - midi - midi beat clock. you want to 'enable midi beat clock' and select the devices that are going to be receiving midi beat clock. all devices that you setup under midi studio should be showing. next, set pro tools' tempo for the session if you haven't already. This setup is based on Pro Tools being the MASTER device and the other device(s) SLAVE(S). Make sure that on your hardware/midi interface that the midi output is going to the midi input on the slave devices. On the mpc, press mode, then pad 9 and go to the sync tab. Choose "slave" under "sync in" and the port, 1 or 2, that your mpc will receive midi input. That's it!! When you start Pro Tools' sequencer, the mpc should start too at the same bar/beat location. I've tried slaving Pro Tools to the MPC1000 and Fantom Xa on diff. occasions but I could never get them in sync with Pro Tools. Tried diff. framerates and settings, but still, no luck. So I prefer using Pro Tools as the MASTER sending midi beat clock. Another thing, make sure that whatever you're tracking into Pro Tools doesn't change tempo during the song. If so, you'll have to edit tempo events in the tempo ruler. Hope this helps!!"
let me know if you need any more help.
Feb 16, 2009 | Akai MPC-4000 Plus Production Center (w/80...
Drum set
I USE THE INTERNAL DRUM MACHINE ALL THE TIME, BUT ONLY ONE TRACK AT A TIME PER SONG. I CAN CUSTOMIZE THE SONG BY CHANGING THE TEMPO, STYLE, AND LENGTH. EACH SONG SOUND GREAT. TRY IT. (DAYSHIFT).
Jan 31, 2009 | Tascam 2488 Portastudio Multitrack...
Change tempo on existing song
No, sorry there isn't any way to speed up or slow down a track with the DP-02. You'd have to export the track to a program on a pc which will allow you to do this whether it is a program which allows you to chnage the tempo and adjusts the pitch for you, or something that will allow you to slice the track or convert to midi and then adust the tempo there.
Jan 19, 2009 | Tascam DP01 All-In-One Recording Package...
Play back problem
At the top center of your screen right above the Play and Record buttons you'll see the tempo indicator. It will read 120.00 BPM or some number like that. Click on the 120.00. You'll get the number with up and down arrows to the right. Click on the arrows to increase or decrease tempo. Or you can hit the backspace ey and type in the tempo you want. Try changing it 10 beats at a time.
Jan 07, 2009 | Cakewalk Music Creator 4
Can't change the tempo on cubase sx
on the play panel click track
Oct 28, 2008 | Steinberg Cubase SX3
Tempo change
click track on the play bar where u edit the tempo thers track and then fixed
Open Questions:
See all Fostex MR16HD/CD Digital Recorder Questions
Fostex MR16HD/CD Digital Recorder Logo
20 people viewed this question
Top Fostex Televison & Video Experts
Henry  Thomas
Henry Thomas
Michael Galve
Michael Galve
Tom Chichester
Are you a Fostex Televison and Video Expert? Answer questions, earn points and help others
