Question about Sony Cybershot DSC-H3 Digital Camera
Changeing resolution Have the resolution set at 72 ppi... how do I change it to a higher one-- at least 200 ppi (@ 6" x 4")?
  • MarenChis Dec 08, 2008
    I need to change to a higher resolution for a better print quality. Has anyone been able to accomplish this? Thanks !
On the back of the camera, push "Menu."
A menu screen comes up.
The first option is the one you're looking for:
"Image Size."
UNDER that option, the first sub-option is "8 M," the next is "3:2," the next is "5 M" and so on. That "M" is "Mega Pixels, or "million pixels." The size of the file will be measured in megapixels, and each "pixel" requires 3 Bytes of memory to define it. (A "pixel" is like one tile in a mosaic tile image.)
You change the options and sub-options in the menu by using the round donut-shaped control on the camera back. On the outside of the "donut" there are arrowheads pointing Up, Down, Left and Right. When you push the donut in the spot next to an arrowhead, you go whichever way the arrowhead points. Up goes through the MAIN options, right/left takes you through the SUB-options under the main option.
Change from a lower file size to a higher one by going left and right through the "Image Size" sub-menu. The biggest file size is "8 M" and I suspect the smallest is at the extreme opposite side of the list.
Someone apparently set your camera, maybe before you bought it, to a file size that is as small as possible, so you could fit the maximum number of pictures in the camera. But to get a better image for printing, you need to change to something with more pixels!
Posted on Feb 18, 2009
  • Sharon Sivertsen
    Sharon Sivertsen Feb 18, 2009
    Maybe it'll help if I include this photo, to show what the Menu button and "donut" are.
Tip
LPI, PPI,DPI conversions
Here is a conversion chart for DPI (Dots per inch) to LPI (Lines per inch) or PPI (Pixels per inch)
180 DPI................31 lines/inch or 68 PPI
360 DPI................63 lines/inch or 138 PPI
720 DPI................127 lines/inch or 280 PPI
1440 DPI..............255 lines/inch or 561 PPI
2880 DPI..................510 lines/inch or 1122 PPI
If you plan to enlarge your image, it is better to enlarge it when you're scanning rather than in your application. Each time you modify
an image, you lose some quality. Keep in mind when you enlarge a small photo, such as a 35 mm slide or wallet-size photo, you'll need
to scan at a high enough resolution to retain your image quality, but not so high that your file size is too large to be efficient. You must
manually adjust the resolution (dpi) to maintain the same image quality when you resize your image. For example, if you have a 300
dpi 2 x 2-inch image that you want to enlarge to 4 x 4 (a factor of 200%), increase the Scale setting to 200% or change the resolution to 600 dpi.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
My pictures are only 72 DPI. How can I change the resolution to higher quality?
The dots per inch setting (DPI) is meaningful only when printing the picture. As such, the camera simply fills in a default value of 72. You can change it in Photoshop or any other photo editing program. The resolution setting on the camera only changes the number of pixels in the picture, not how you print it.
Feb 16, 2012 | Casio Exilim EX-S12 Digital Camera
How do I increase the dpi on TZ5
Hi - When talking about resolution in digital photography there are two main meanings.
One is the "pixel count resolution" and the other "embedded resolution". So for example your camera could record 2272*1704 as the actual pixel count resolution and set 72 as the embedded resolution that tells other software (for example photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it in your software to 300 for printing. In Photoshop you can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions".
So for your camera the embedded resolution is 180 which you can only change in your PC software.
This is a complex subject, I recommend looking at the following web page:
http://www.fotofinish.com/resources/centers/photo/resolution.htm
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 13, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
Resolution problems
A quick and easy solution would be to use a CF card reader. You will find that the transfer rates are higher too. With a card reader you will be able to copy your images to any system running Windows, Mac OS or Linux without installing the camera's software.
Dec 25, 2007 | Canon Rebel XT / EOS 350D Digital Camera
CHANGE DPI
Yes, every picture has a resolution of 72 ppi. This can be changed later in an image editing program on the computer.
Nov 25, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Canon Rebel xti vs Photoshop!
What you are seeing is the difference between "pixel count resolution" and "embedded resolution". So in your example 2272*1704 is the actual pixel count resolution as recorded by the camera & 72 is the embedded resolution that tells the software (in this case photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it to 300 for printing. You can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions". This is a complex subject, I recommend looking at the following web page: http://www.fotofinish.com/resources/centers/photo/resolution.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 15, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Minolta Dimage S414 Problem with resulution
Aug 08, 2007 | Konica Minolta DiMAGE S414 Digital Camera
Messed up CD400 resolution
Hi Molly, The 72 ppi figure is merely an arbitrary starting point used by most image editing software. I've known others to use 300 as a default, e.g. Paint Shop Pro last time I looked at it. Why it should have changed I can't tell at this point, unless you've changed your software; but it's not important. The figure is meaningless until you want to *print* your images, and even then it's best to just set print size *without* resampling the image, and let the resolution look after itself until you have a need for very large prints. To see what your camera is capturing, the essential figure you need to be interested in is the images' *pixel dimensions*; and in the case of the CD400 they should be 2272 x 1704 at the camera's full res. setting. (Actually, "resolution" is an unfortunate term, in its popular usage. Resolution really describes how thinly or densely the same pixel count is mapped over the intended physical output size.) Changing the print size *without* resampling the image will cause the resolution figure (72, 300 or whatever else it might be) to change inversely with the print dimensions, but will not change the overall pixel dimensions of 2272 x 1704.
Sep 13, 2005 | Sony Mavica MVC-CD400 Digital Camera
Sony Cybershot DSC-H3 Digital Camera Logo
120 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
