I replaced all the ink on my brother MFC4420C, I don't get any error message, but nothing prints when i try to make a copy
    Problem Solver:
  • 20 Answers
I think theres a problem with your printer maybe you use a compatible ink or your using your printer very minimal. follow this simple steps; try to clean the nozzle (properties then click maintenance on you pc ) repeat untill its ok. Avoid using Fast draft so it may only help clogging the printer head Use NORMAL PRINTING. Try to print one page every day to avoid head clogging . Finally, don't place your printer on direct sunlight.
yours,
alecz
Posted on Apr 23, 2008
ERROR MESSAGE SAYS UNABLE TO CLEAN
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
Apr 30, 2010 | Brother DCP 115C All-In-One InkJet Printer
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
I received an error message that ink cartridges needed replacing. I replaced the ones stated and checked the ink levels on the computer. The report is that the ones replaced are at 100% and the others have...
If you are using refilled (worst cartridges) or third party cartridges then that is most likely the problem.
If you are using factory new HP cartridges, then you need to contact HP to get the cartridges replaced.
Don
Feb 25, 2010 | HP Photosmart C6180 All-In-One InkJet...
Brother MC420CN- Black ink cartidge 'near empty' message persists
At 1 of the end sides of the cartage you will see a little window, a beam of light hits that window to determine if you need Ink..Place a small piece of Electric tape over that window and.wallah print,fax and copy away. Brother is a ripoff-A cheap printer that auto-cleans(wastes ink) and locks the whole system claiming your out of Ink or low>>>But this is sure to work! ;)
Nov 01, 2009 | Brother MFC 420CN All-In-One InkJet...
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
HELP ON MFC-240C
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Sep 01, 2008 | Brother MFC 240C All-In-One InkJet Printer
Printer constantly shuts down on machine error 41.message reads shut unit down and call Brother.unit is a Brother mfc4420c
Dear KDBALANE,
If you got this error-41 ,then its mean that Printer head is End of life. there is no solution for this error.is your printer in warranty or out of warranty? if this is in warranty then , contact to Brother , they will replace you printer .
Mar 11, 2008 | Computers & Internet
Error message on my Brother MFC-420CN
press menu then start bk copy then fourtimes arrow-up button. Machine will switch to maintaenance mode. You may have to press start bk-copy. The machine will display an error code.
Error code starting with 4 is always a defective print head which needs replacing (except error 46: new waist ink tank needed).
In case it is another error code plz post here again.
Jan 28, 2008 | Brother MFC 420CN All-In-One InkJet...
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
76 people viewed this question
k24674
jasbo
jasbo
