Question about SanDisk Sansa e260 MP3 Player
Where do you switch the usb to MSC? That I don't get....
  • Sunja Mei
    Sunja Mei Apr 24, 2008
    Okay, thank you, but one more thing... Mine won't do it. Im trying to delete the songs off of it and nothing! Im getting frustrated and I have to use my stupid ipod.
  • 758 Answers
Go to menu, settings, USB mode
There should MSC and MTP there
Hope that helps
Please rate accordingly
Thank you
Computerrep
Posted on Apr 23, 2008
Enter usb2.0 msd mode - pls help
Usb mode is in settings push center button choose between msc or mtp....
MSC will allow you to see the expansion card mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode.... make sure your usb 2.0 driver is installed....... Connect to the mother board.. MSC is best create a music1 folder and put music in there then there is no switching back and forth to mtp ms....MSC can sync the player and the expansion card
Dec 19, 2010 | SanDisk Sansa e260 MP3 Player
My sansa m230 driver mp3 player is not detected as removalble disk i mean as a flash drive on my laptop how can i fix this issue
When you're able to change USB mode in the display:
- From the Main Menu, select Settings > USB
- Select in "Auto Detect", "MTP" or "MSC": choose MSC for viewing the player as a removable disk.
When you cannot select MSC mode in the player's menu, force MSC mode with the player switches/buttons:
1. Turn device OFF.
2. Facing the hold switch: slide it to the right so an orange color would show, putting the device on Hold.
3. Connect the device to the PC with the provided USB cable.
note
In MSC mode: Before disconnecting the USB cable always go through the safely remove hardware icon in the lower screen of your computer on the right. Left click the icon to see all removable disks and left click on the removable disk drive letter of the player to disconnect: after the message you can take out the USB cable.
Jul 03, 2010 | SanDisk Audio Players & Recorders
I click on the music folder and nothing's there. This is a macintosh computer
To see music in the music folder on your computer, change to MSC in USB mode in the player from:
Main Menu > Settings > USB mode
For firmware FW 1.01.11 and below on the Sansa Clip the selection for USB mode switching is not available: For adding this selection update the firmware of the player.
You could also force the player into MSC mode using switches/buttons on the player.
0. Player not connected to the computer.
1. Turn device OFF.
2. Slide the Hold switch down to Lock (orange color showing).
3. Press and hold the center button while connecting the device to the PC.
When using iTunes, the player should also be in MSC mode. How to transfer music with iTunes on a MAC computer:
http://kb.sandisk.com/app/answers/detail/a_id/1141
May 27, 2010 | SanDisk Sansa Clip MP3 Player
Keeps turning off
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Mar 05, 2010 | SanDisk Sansa Fuze MP3 Player
Sandisk Fuze 4GB locked lights on will not do anything what do I do ?
Mar 05, 2010 | SanDisk Sansa e260 MP3 Player
I don't know how to reset my Sandick Sansa e260 4g?
Mar 05, 2010 | SanDisk Sansa e250 MP3 Player
My sansa won't turn on
Feb 23, 2010 | SanDisk Sansa e250 MP3 Player
My mp3 was on but now it won't come back on or charge.
Reset the player:
Then try this
- If the player does not turn on try other USB ports2_bing.gif or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub2_bing.gif.
If you receive the error "USB Device2_bing.gif Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
<<<<< BUT TRY THIS FIRST >>>>>
MTP mode is the recommended and default method for Sansa Players when used with Windows OS2_bing.gif.
Solve your MP3 Player Connection Problem.
Refresh the drivers
Feb 21, 2010 | SanDisk Sansa Clip MP3 Player
RCA M4204-A: switched from MSC to MTP...now USB deive is not recognized by my computer. How do I change it back to MSC?
Power on the device. In the menu, go to settings. Switch the "Protocol" from MTP back to MSC.
Oct 13, 2009 | RCA M4204 MP3 Player
Windows Vista problems
try switching to MSC on the player's USB setup.
Mar 16, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
