Question about Mitsubishi WS-55513 55" Rear Projection HDTV
The v-chip is locked - Mitsubishi WS-55513 55" Rear Projection HDTV
How do I reset the VCHIP lock? I don't have the old passcode.
Posted on Nov 15, 2008
My vchip is locked i dont know the password what do i do?
Posted on Dec 08, 2008
After replacing the dlp chip in my mitsubishi tv there are vertical lines on the screen. any ideas?
i had the same lines on my 65' mitsubishi tv after replacing the DLP chip. after going back over everything i realized that the casinf that holds the chip in was not in the lock position. i took the chip out and replaced it then turned the little locking mechanism to the locked position. now my screen is perfect. hope this helps.
Nov 21, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
Tip
Bypass V-Chip Mitsubishi TV
Bypassing the V-Chip Lock on most Mitsubishi sets:
Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you don't have the passcode, it is easy to bypass. This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it.
To bypass the V-chip: You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your passcode is requested. This process temporarily unlocks the TV.
To reset the code: When you use the button combination 9 and QV while entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
on Mar 20, 2010 | Televison & Video
How do i get the v-chip lock code to unlock the parental lock from my Mitsubishi model code ws-55413
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked TV without entering your passcode. When your password is requested, press the number 9 and QV buttons on the remote TV control at the same time. This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode
hope this helps
John.
Jan 11, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The power is not coming on, and when it does it says LOCKED, I don't have the original remote but I am using an RCA universal remote. How can I get my power back on??
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip Lock menus. If you forget your passcode, you can view the locked TV without entering your passcode.This is done by pressing the number 9 and QV buttons on the TV remote control at the same time, when your passcode is requested.This process temporarily unlocks the TV. When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.Press HOME to exit the menu.
Jan 05, 2011 | Hitachi 51G500 51" Rear Projection...
Can not turn off the vchip channel lock on hd 1080
hello try this Bypassing the V-Chip Lock
passcode. This is done by pressing the
TV control at the same time, when your
password is requested. This process
prompts you to enter a new passcode. good luck
regards
shaun
May 14, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi TV model ws-48315 v chip locked
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Apr 29, 2010 | Mitsubishi WS-48315 48" Rear Projection...
How to change the v chip code to a mitsubishi medallion projection tv 62
Good luck, and let us know how you made out with this TV set.
V chip locked up and dont have the code
TV without entering your passcode. This is done by
new passcode. Press HOME to exit the menu.
Bypassing Front Button Lock
If you have misplaced the remote control, you can
bypass the front button lock by pressing and holding
the MENU button on the front panel for more than 8
seconds.
IMPORTANT
Cut along the dotted line and file
bypass instructions in a safe place for
future reference.
IMPORTANT
changing or deleting your
you must use the remote
;ontrol included with this TV. You
use a Mitsubishi remote
_ontrol from another component
Sep 30, 2009 | Mitsubishi WS-65515 65" TV
Memory card locked
There is a tiny button on the side of the card - so small you can hardly see it. Just slide it up and voila All is solved.
It is frustrating as there is nothing in the manual bout this and the onl line assistance wants to charge for 20 seconds advice Mine is free dorothy
Mar 24, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
V chip codes
LauriJo...
From the back of my Mitsubishi Owners Manual, Appendix A
"Bypassing the V-Chip Lock
If you forget your passcode, you can view the locked TV without entering your passcode. This is done by pressing the number 9 and QV buttons on the TV remote control at the same time when your passcode is requested. This process temporarily unlocks the TV.
When entering the V-Chip lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode."
I hope that helps you.
Nov 02, 2008 | Mitsubishi WD-52526 LCD TV
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
