Question about Philips DVDR3575H/37
Hdd recorder / recording & watching cable channels
I have a dvd hdd recorder, connected to cable, I want to record on one channel, while watching a another channel. Is there a product I can buy for this type of set up?
  • McD-CA May 02, 2008
    Thx for your info response dutchman05, which was helpful. I had also learned about the splitter solution after making a call directly to the GeekSquad. They immediately forwarded me directly to a Philips Master Technician, who also explained the splitter connection to me.
  • soumifin Aug 23, 2008
    Just bought the Philips DVDR3575H/37. I am an ex computer geek and pretty good at following instructions. We have Charter Cable, Charter broadband internet and Charter telephone. I followed the directions for connecting the Philips inbetween the cable box and the TV (an 8 year old 30 inch JVC that has the capability to have 3 seperate inputs with RCA cables). Once connected the instruction said to turn on the DVDR and the TV to get the initial setup screen with no mention of the cable box. I never got the Initial setup screen. I then followed the General Setup instructions to do an auto scan.
    I have tried auto scan analog and analg/digital without the cable box on and with the cable box on. None of the attempts has given me anything more than cable channel 3 on a couple channels using the DVDR tuner. Everything would be fine if I only wanted to record what I'm watching, but kind of defeats the purpose of having a recorder with a digital tuner.
  • 487 Answers
Yeah actually that is kinda simple. Like the old vcr recorders you can just put a splitter between the cable (input) and your dvd hdd and your tv.
that is an easy 3 dollar solution
Posted on Apr 30, 2008
How connect Magnavox DVDR to Comcast Cable Box ?
You'll need to use the direct input on the rrcorder from the DVR video output.Some channels won't record as they're encoded
Sep 25, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
Hd recording
If the digital tuner can pick up the HD channels, then I don't see why it can't record them. However some TV channels have blocking on them to prevent recording. If it can't record a channel it will say so with a message, generally.
Jan 22, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
I am having trouble in connecting the new dvd recorder . I think ,I am missing some thing on the initial set up to receive the channels our present configuration is ... 1.R F cable input to set top box,...
I found your model information on a site which provided something I was going to ask you if I could not find it.DVD recorders need either a digital input from a cable box or a self-contained digital scanner(yours does not have this).So,you need to hook up as follows,External cable into cable box input,cable box output into DVD recorder input,DVD recorder output to TV coaxial cable input(usually labeled ant.)the screw on connector anyhow,you should know what I mean it seems.In this configuration,you should not need to turn on the DVD recorder to watch TV without recording because they usually have a bypass mode when there is no power on the DVD.If you have picture in picture(PIP),you should be able to use the main source to record and switch over to the PIP channel if you do not want to watch what you are recording.Do about a 10-30 second test of that just to make sure though so you don't end up all messed up.Oops.My bad...you do not have PIP.As long as the cable box is tuned to the channel you want to record,you should be able to use the TV's tuner to watch something else with no problem.When doing this on VHS recorders,sometimes the screen would get fuzzy and you would have to press the TV/VCR vutton on the VCR remote.I do not know if a DVD recorder will do it or not as I have yet to buy one,but when you do your test recording,you can mess around with whatever you want to see what happens so you will be fully prepared when you do it.If you need more help or have a problem/question,just comment here and I will get an autolink to your post and will reply ASAP.Good luck! Greg
Sep 26, 2010 | Coby DVDR1280 DVD Recorder/HDD Recorder
I purchased a MDR513h/f7 hdd & dvd Player/recorder for my cable TV. I can not watch one channel while recording another. Comast said I must have a dual turner and that is what I purchased (I think)....
This model has only one tuner, I'm afraid. You can only watch one channel at a time, unless you split the cable signal going into it. One side goes to the recorder, the other to the TV. Then you use the single tuner in the recorder to record and the TV's tuner to watch the other channel.
Sep 12, 2010 | Philips Magnavox DVD/VCR Dual Player
Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
Nov 23, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Record and watch different channels with freesat
I believe that the Humax can only output 1 channel and because it has no built in hdd and twin channel capabilty that is all you can record 1 channel (unlike sky +/sky HD) so that means also that unless you watch a different source (like the picture from your aerial (terrestial channels)) you are stuck with having to watch the channel you record
Oct 12, 2008 | Televison & Video
Watching another channel while recording
Hi there! Sorry but you can't unless you have My Sky/HD recorder. The sky decoder is simply a one channel watch decoder. You can only record a sky channel and watch the channels normally provided via your VHF and UHF aerials connected to the decoder or vice versa.
My Sky fixes that although you cannot record to a dvd disc on this thing and the privilege comes at a price of course!
Aug 03, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Watch while recording
Make sure the DVD has RF lead and Scart lead connected in and also BOTH connected out to the TV. When you record from TV use channel numbers, when you record from cable use AV channel, (on DVD). When watching TV use TV channels 1 to 5, when watching Cable use AV channel, (on TV).
Feb 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Philips DVDR3575H/37 Logo
129 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
