Question about GPS
Address when I start an address it goes well with postal code then house number and hit done,next comes street name but garmin takes(a guess) which when wrong I can't change ,if I hit back and start over it's goes the same way. I just got this unit and the manual don't explain
  • blondema Sep 24, 2008
    why can't you put in a route # instead of street address if you are using the Via Directions?
I found out that my road is not on the garmin map,therefore it goes to a road or street
that has the same house number
Hilroy
Posted on May 01, 2008
Trying to type in an address on my 1st gps.
The manual can be downloaded from Garmin.
www.garmin.com/manuals/3130_OwnersManual.pdf
1. Touch Where To? > Address.
2. Change the state, the country, or the province, if necessary.
3. Touch Search All. If you know the city, touch Spell City, enter the city/postal code, and touch Done. Select the city/postal code in the list. (Not all map data provides postal code searching.)
4. Enter the number of the address, and touch Done.
5. Enter the street name, and touch Done.
6. Select the correct street in the list, if necessary.
7. Touch the address, if necessary.
Dec 14, 2011 | Garmin Nuvi 1350LMT
My garmin doesn't recognize an address
If you are having problems finding a particular address, try some of following tips. In some cases the address may be listed as being in a different city other than the one that was chosen. When the unit asks for the City Name, try choosing Search All Cities. If the address is listed under a different City Name, doing this will allow the unit to find the address. Also, when entering a street name, it is important that you leave off any direction or label. For example, if the address was 2536 SW Melrose Place, you would enter 2536 for the house number and only Melrose for the street name. Using the house number and city/state, the unit will fill in the direction (SW) and label (Place).
If you are still unable to find the address, the mapping may not have the address available yet. Please report this to our Cartography department using the Error Report Form which can be found at the following link:
http://www8.garmin.com/cartography/mapSource/errorForm.jsp
May 21, 2011 | Garmin nuvi 260W GPS Receiver
Postal code in hongkong thanks!
Looks like you just omit the postal code (they don't use it):
http://postal-codes.net/hong-kong
Mar 01, 2011 | Computers & Internet
When I press address it goes straight to Street. It doesn't ask what State. If I put in address....it says not found. Brenda Romero
need a lot more info .... what gps model do you have,
your saying you put address it goes straight to street? then say i put addrees it says not found
Most Nuvi units you have to press Where To...Address....and on the bottom of screen you will see Change State / Province
First select your State..... then go back and select the City... it should now let you put the number of house press done ..then the street name
Nov 06, 2010 | Garmin GPS
When i type in an address it says no matches found. any address
start with a basic address of a main st in your city and see if it finds that. be sure to separate the street name and st,ave,rd. i.e
enter in the house number 123 done.
enter in the street name bank st done.
this should come back with a street for you. if not make sure there is a map location for the street you are trying to find. a newer neighbourhood may not be listed in your gps.
Oct 28, 2009 | Garmin nuvi 205 GPS Receiver
Garmin Street Pilot c330
Have you tried resetting the unit?
Jul 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin 350 won't let me enter City/Postal Code
Have you tried doing a hard reset to see if this clears the problem?
May 25, 2008 | Garmin nuvi 350 GPS Receiver
Postal Code
How are you entering the address? And, as far as I know, you won't get much with a postal code since it covers so many addresses. Now, if you meant Post Office Box number, they won't show because they are housed in a single building and the gps will only find STREET addresses.
Jan 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Keying in street addresses
To find streets that are numerical, not names, enter the address normally to start. Enter the State, City, and House Number. When it asks you to enter the street, look at the bottom of the keyboard. You will see a key marked 123. Press this key, and numbers will show up instead of letters. Type in just the numbers (25 for 25th Avenue, etc.) and hit Done. The street should show as (25th (St., Ave., etc)). Press the correct entry.
Dec 04, 2007 | Garmin StreetPilot c550 GPS Receiver
StreetPilot c 340 does not allow to enter address
Ok, you've tried a reset, but have you tried a Master Reset? Doing this WILL ERASE ALL OF YOUR FAVORITES, but it may help. Turn the unit off. Press the "On" button with your finger on the bottom right of the screen at the same time. Release the "On" button, but keep pressing the screen until the unit asks if you're sure you want to reset all data. Press "Yes". See if this helps.
Nov 04, 2007 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
108 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
