Question about Frigidaire CWS3600AS Top Load Washer
Fidgidair cws3600as1 washer leak
Washer is leaking from transmission shaft seals. I took them off the shaft and cant remember how they go back on.
  • Anonymous Mar 25, 2014
    leaking oil into washer, no funny noises guessing the transmission seal is bad; how do I replace?
    Genius:
  • 1,073 Answers
If you took them off then you have to reinstall a new set top seal with smooth side down
Posted on Apr 23, 2008
97 thunderbird transmission fluid leak
Both of these answers are the same and I will give you a 3rd and the funny things is they are all the same.
OUTPUT SHAFT SEAL
Apr 05, 2013 | Ford Thunderbird Cars & Trucks
Kenmore 417 97962705 Leaking below tub from transmission gasket
see this causes and fix it. God bless you
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front.
Sep 28, 2012 | Kenmore 98702 Stacked Washer/Dryer
What would be a cause of leaking transmission fluid?
The most common cause is the front seal of the input shaft is leaking, this is commonly called the front pump seal, next would be the transmission pan gasket is leaking. The only real way to determine exactly what is leaking is to thoroughly clean all the fluid off with a pressure washer, then drive it and check for the source of the fluid.
Oct 11, 2011 | 1993 Buick Regal
Notice on driveway tranmission fluid leaking check t f top off also first gear hard shift took to DOBBS HAD CHECK OUT WAS TOLD tranmission seal on back side was leaking bad also oil pan gasket leaking...
u get a second look your self by looking at the transmission u dont have to take anything apart to find the leak the oil pan is easy so check that one first if u see any fluid on or around the pan then the seal is shot that dont mean the tranny will burn up, just keep an eye on the fluid level second the rear transmission seal is located at the back of the tranny where the rear drive shaft slips into the transmission if you notice fluid around there and on the drive shaft thats leaking also but like i said just because u have a few minor leaks dont mean the tranny will blow up just as long as you keep an eye on the fluid level. do your home work and find a good transmission shop that will gaureentee the there work at a decent price.
Nov 27, 2010 | 1999 Dodge Ram
Washer leaking water during wash cycle. Does not
There is a bad seal where the tub mounting with the transmission shaft to cause the leak. It leaks when it tuns. To access this, the agitation fin need to be out so you can see the big nut holding the tube in a place with the shaft. Below this nut is a seal or gasket to prevent the water getting out of the bottom tube. Replace this then you are good . Good luck.
Apr 21, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Leaking fluid from rear end
hello, fluid leaking out of rear end is probably the pinion shaft seal, its were the drive shaft hooks to the rearend, you have to drop drive shaft, take yoke off rearend, or if it is,more further towards the back,were wheels are, then you need axle shaft seal, you have one on both sides on the rearend, behind the drums, where the back brakes are, also look and see if its coming from back of transmission, where drive shaft goes into the transmission, see if you can tell what color fluid is, if its red, its probably rear transmission seal, where drive shaft goes into the transmission.
Apr 08, 2010 | 2003 Kia Sedona
If i set the load size to extra large, water comes out of the bottom of the washer and the belt starts making a shreaking noise
The noise is from the belt getting wet.
Check the pump inlet and outlet hoses for rupture or loose clamps.
Thanks for using FixYa - a good rating is appreciated for answering your FREE question.
Jul 08, 2009 | Washing Machines
Leaking Rear Transmission Seal
Did you use a motorcraft seal? aftermarket seals are not as good, the factory seal is double lipped as far as I remember.
Nov 30, 2008 | 2000 Mercury Sable
GE WBXR2060V1WW leak_transmission shaft and tub
The tub seal is leaking, often this damages the transmission. A new tub seal comes with the transmission this page should help http://www.appliance-repair-it.com/GE-washer-disassembly.html
Nov 12, 2008 | GE WDSR2080D Top Load Washer
Frigidaire CWS3600AS Top Load Washer Logo
164 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
