FixYa.com
Tags:
Motherboards
Generic problem for all Motherboards
Need to know where the black yellow speaker wire...
posted by josher_09 on Apr 23, 2008
i got a black and yellow speaker wire and do not know the exact location to where it goes if anyone knows the name of the port on my mobo that would help me out alot i have a k9a2 platinum
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 23, 2008
Not Rated (0)
map9966
Rank:Guru Guru
Rating: 88%, 1130 votes
MSI K9A2 Platinum (MS-7376)
Front Panel Connectors: JFP1, JFP2
Page 2-16 in the manual. To connect system speaker look to JFP2.
Black is ground & the yellow is +, plus power.
Front Panel Connectors: JFP2.
Need manual.
http://global.msi.com.tw/index.php?func=downloadfile&dno=6017&type=manual
MSI K9A2 Platinum main page.
http://www.msicomputer.com/product/p_spec.asp?model=K9A2_Platinum&class=mb
Good Luck!
Mike
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
mewms_14904
Rank:Guru Guru
Rating: 88%, 646 votes
Audio Ports
These audio connectors are used for audio devices. You can differentiate the color
of the audio jacks for different audio sound effects.
Line-In (Blue) - Line In, is used for external CD player, tapeplayer or other
audio devices.
Line-Out (Green) - Line Out, is a connector for speakers or headphones.
Mic (Pink) - Mic, is a connector for microphones.
RS-Out (Black) - Rear-Surround Out in 4/ 5.1/ 7.1 channel mode.
CS-Out (Orange or Yellow) - Center/ Subwoofer Out in 5.1/ 7.1 channel mode.
SS-Out (Gray) - Side-Surround Out 7.1 channel mode.
This Problem Also Relates To: HP (5185-6477) Motherboard HP (P2074-69003) Motherboard ASUS P5S800-VM Motherboard ASUS A7V8X Motherboard ASUS P5B-E Motherboard ASUS P5B Deluxe/WiFi-AP LGA775 Core 2 Duo/ P965/ A (MB-P5BDLX) Motherboard ASUS (P4BP-MX) Motherboard
Can you Help with these Motherboards problems?
PC Chips M810DLU (M810DLUV75C) Motherboard
BOOT falilure after RAM...
history: every time when the... Answer This...
After I installed a new memory...
When I replaced it with an old... Answer This...
Intel Motherboard
Bios updation
how to update the intel 102gc... Answer This...
Intel D845GVSR Motherboard
Emachine t3958/d845gvsr mobo
Having problems getting a... Answer This...
HP Compaq Motherboard
Compaq Presario SG3430IL...
Hi i bought a new Compaq... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
