Question about Insignia NS-DVDR1 DVD Recorder
Black & white picture
When i am in dvd mode the picture is in black & white with a code YPbPr
Make sure the PAL-NTSC shift is correct.
Posted on Jun 15, 2008
  • 121 Answers
YPbPr refers to the 3 wire component cables designed for HD presentation. These would be RCA type (red, green and blue coponents). 'One" can assume that your DVD is currently set up for HD but you do not have the proper cables attached.
Posted on Apr 23, 2008
Picture won't display. YPbPr is flashing on screen
go to settings and select the computer mode instead of YPbPr
the image from the computer will be seen
Dec 16, 2012 | Panasonic PT-AE700U Multimedia Projector
I have a toshiba 19w330db tv and already have a virgin media box and toshiba SD220EB dvd player connected. I am trying to connect a nintendo wii using the AV cable provided and am using the audio L R...
Do I understant this correctly? You are using a composite video cable (A/V y,r,w) and connecting it with the component video input (and then telling the TV to use the YPbPr source). You need a component video cable (3 RCA plugs on each end - red, green and blue) and an audio cable (2 RCA plugs - red and white) for the Wii. It wasn't included with the Wii but it does have the component video ports. Otherwise you would need a SCART to composite connector to work with the input. Alternatively, you could get an HDMI cable and connect that between the Wii and the TV (depnding on the age of the Wii).
If I've read this correctly, you have the media box and dvd player sharing the SCART input (EXT1).
I hope this helps.
Dec 26, 2010 | Toshiba Televison & Video
REMOTE OPERATES PLAYER BUT NO PICTURE....DO I HAVE IT HOOKED UP RIGHT ???
DVD players generally have 4 possible ways to connect them to a TV set.
1. Composite Base-band Video or RCA's (Yellow, Red, White)
2. S-Video or Super Video (S-Video, Red, White)
3. Component Video or YPbPr (Red, Green, Blue, Red, White)
4. HDMI or High Definition Multimedia Interface (HDMI)
If you are sure that the connections are correct at both ends make sure that the TV set is on the proper input for the DVD player's signal by pressing the input button, source button, or the proper input button as listed (some remotes have a separate button for each input) on the TV remote.
Feb 26, 2010 | JVC Televison & Video
Black and white only when playing a DVD or VHS hooked up to my Sony Bravia 32" LCD TV.
What type of connections are you using?
If you are using coax cable check to make sure that the TV is on the proper channel that the DVD/VCR is switched to i.e. 3 or 4.
If you are using Componant video (red, green, blue, and red, white) verify that the green is plugged in all the way on both the TV and DVD/VCR and try connecting it to a different Componant input on the TV.
Note: the TV may be YCbCr, and DVD/VCR YPbPr or vice versa these two types usually are not compatible with each other. YCbCr is a digital signal and YPbPr is an analog signal.
If you are using A/V video cables or (yellow, red, white) check the DVD/VCR video setting to see if it is in progressive scan mode, as this can cause a problem with some TV sets that are not compatible.
Feb 05, 2010 | Goldstar GVR-E435 VHS VCR
No picture
try to connect it the component input at the hdtv using the ypbpr out from your dvd. and switch it to interlace mode at the menu of a remote control and try to connect to video.
Sep 25, 2009 | Televison & Video
Split screen
just open the menu and go to tv settings then adjust it to interlace mode.or use your component input if your tv has an ability to receive a YPBPR input much clear than an ordinary video.
Sep 24, 2009 | Televison & Video
Only black and white picture on screen when showing DVD
its a PALSECAM mode. change mode to NTSC! that y black & white picture. click button PAL/NTSC.
May 25, 2009 | Sony Dream System DAVDX155 Theater System
DVD picture is in Black & White only.
Are you trying to play an NTSC disc in a PAL player, If so,your player has a switch or
on-screen setting to select the output format for NTSC discs,
Or maybe you have connected one of the component outputs (Y, R-Y, or B-Y) of
your DVD player to the composite input of your TV.
Please rate this solution
Jan 20, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Dvd lg
I would need the exact model number to be sure, but there are 3 possibilities:
1) there are red, white and yellow (composite) cables plugged into a slot designed for red, green, and blue (component or YPbPr) cables
2) you have an S-Video cable AND another type of cable plugged into unit at same time
3)the progressive scan has been either activated or deactivated - read your manual to find out how to turn it off [warning: if I am wrong, then turning on the p-scan may cause you to lose picture which is difficult to reverse on some DVD models - I would definitely look into the other possibilities first]
May 23, 2008 | LG Televison & Video
Black and white picture
try switching modes form NTS or PAL
Sep 13, 2007 | Cyberhome CH-DVD 300 DVD Player
Insignia NS-DVDR1 DVD Recorder Logo
167 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
