Question about Samsung Digimax D53 Digital Camera
Beeping samsung digimax d53 will not come on with fully charges batteries//just gives 3 short beeps
  • 41 Answers
The beeping is as a result of low power. I found several articles on-line about this, and you are not alone. The best solution I saw was to use NiMH Rechargable batteries. They say it takes the life from 30 shots, to 30 days worth of shots if you get the correct rechargable AA Batteries.
If it is not power, then I am sorry, but I am of no help.
Many people complain about the life of batteries, and this beeping though, best to try it, and see.
Posted on Apr 23, 2008
I HAVE A DIGIMAX D53 AND WHEN I TURN IT ON THE MONITOR HAS A DULL LIGHT BUT FADES AND BEEPS 3 TIMES. i DO NOT GET A A MENU OR PICTURE WHEN I HAVE A MEMORY CARD INSERTED.
Does it turn off immediately after the it beeped? Are you using a rechargeable battery? Have you tried fully charging the it? You should also try fresh set of batteries and see if it will resolve your problem.
Oct 20, 2011 | Samsung Digimax D53 Digital Camera
Digimax S800 Samsung : Lens won't retract
check first if battery is ok, maybe your problem is your barrel, if barrel not function properly you need to change motor or barrel allignment. if barrel is ok you have short circuit in your assy pcb main.
Apr 23, 2010 | Samsung Digimax S800 Digital Camera
The lens is stuck open and nothing will work. Every time I try to turn it on or push a button it beeps and turns off.
First, make sure you have a charged battery. Once you have that, try turning it on, and gently press on the lens to try to help it reseat. You might try googling the problem, there are free suggestions to try before you take it to a repair facility. But if you do decide to have a shop fix it, get an estimate first. Oftentimes, the repair is about what you will pay for a good, used camera on Ebay.
Feb 22, 2010 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 wont turn on at all brand new batteries and still wont turn on
Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 12, 2009 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 Camera says low battery but just replaced with brand new ones. Camera beeps and shuts down immediately.
For digital cameras you should use either Rechargeable(whith high Ampere) or high performance alkaline batteries (ie. Lithium Duracel or Enegizer) normal alkaline batteries will not be able to charge the Flash. If you are useing high performance batteries then it is sadly your camera which is faulty. repairing it you could but it is cheaper to get a new camera.
/SciPhinx
Jul 22, 2009 | Samsung Digimax D53 Digital Camera
D53 camera will not fully turn on...help??
If you've tried the suggestions for similar problems on here - use NiMH or lithium batteries (not alkalines), then it may be a warantee job. Afraid I don't have any other suggestions.
Sep 05, 2008 | Samsung Digimax D53 Digital Camera
Problem with startup
my samsung d53 issue is .when u turn it on it beeps 3 times and shuts off. thats all it does.... cant take a picture its like the batteries are low.But they are not. what is wrong. like new! jimmy
Jan 27, 2008 | Samsung Digimax D53 Digital Camera
Camera will not turn on
Are you sure the batteries are fully charged? I would suggest using rechargeable not alkaline batteries.
Nov 09, 2007 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 camera
lenses are jammed. send it to a service technician. sorry.
Oct 03, 2007 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 Digital Camera Logo
200 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
