How to fix a scratch on toshiba-flat-screen-tvs
  • 8,617 Answers
You cant you will need a new screen.
Posted on Apr 23, 2008
My house was struck by lightning now my tvs wont come on. how do i fix them or reset them?
have you checked the fuses in the plugs to make sure they have not blown?
Dec 01, 2016 | Panasonic Televison & Video
Bad scratches on screen
3m makes a light rubbing compound that i use, with a cotton towel i gently massaging the screen across the scratch then in a lite circular motion then i use a microfiber cloth to wipe down this also works with the frames of TVs from moving scratches don't press to hard i usually do this on a blue screen or on a one color screen the compound is the equivalent to 1200 sandpaper a 64oz bottle is 50 bucks
Jun 10, 2014 | Akai Televison & Video
Fix vertical lines
Check the LVDS cable connections at its both end for any loose contact. Reset it once and check. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts. Screen shots to defective LCD and Plasma TVs are given. you can compare it to that of your TVs' and make sure about the fault.
Dec 03, 2013 | Toshiba REGZA Televison & Video
I need to know how you fix the screen on a flat screen cause it was scratched by a pepper grounder
The panel has to be replaced. That will almost always cost more than a new television.
Apr 05, 2011 | Toshiba Televison & Video
Where can i find a replacement for my broken screen
The tvs screen panels are 90% important to the tvs.Sorry,LCD tvs screen panels or any other tvs screen panels for that matters are limited production by the tvs industries.No, where u will able to find and buy or replaced the tv LCD screen panel,but must buy the LCD screen panels from the tv industries themselves.They'll sell it to u,but they'll charge like the new LCD screen panel same as a new tv.Sorry ur tv now dosen't worth as a whole tv anymore,now it only worth as a salvage tv for it electronic boards for parts,that it.
Oct 27, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
My daughter has scratched the screen with a toy how can i remove the scratches
Sorry! there are no chemical solution yet,that could remove scratches from the LCD or Plama tvs screen.You have to live with the scratches.
May 18, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
My son hit my lcd tv with his match box and put several nicks in the screen can I fix it with out replacing it???
yes go to best buy and there is a scratch remover for screen it worked well for mine depending how deep the nicks are
Jun 04, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
Scratched screen from moving
If you were moved by professionals, perhaps you can file a damage claim?
Both the scratch and the colored lines warrant the replacement of the VERY expensive LCD panel.
Sorry, Mary, but this is not something that you can fix yourself, nor would you want to.
www.mcveyelectronics.com
Apr 12, 2009 | Toshiba 42HL167 42 in. LCD Television
Repairing screen on a flat screen tv.
the screen alone is gonna be expensive for those tvs your best bet is to buy a whole new tv because to replace it is gonna cost the same for a new tv unless their is a warranty
Jan 31, 2009 | TruTech PLV16320 Television
Front screen
HOW TO CLEAN TV SCREEN;
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
