I've never used my camcorder before and the first time I took it out of the box and tried to put a tape in I found that the tape compartment will mechanically eject but wont go back in with or without a tape. And, no, I didn't try to force it. Now I can't use the camera at all because the stupid thing is sticking out (whether the camera is off or on) and I can't even go with just memory card. HELP!
I have the same problem and it is very ennoying! But, there is a solution. This SAMSUNG camcoder model has a sensor that reads when the compartment it is pressed down. A solution to your problem(wich was also mine a few weeks ago) is to press down the cam's compartment until you hear a noise, and the...held it like this for 1-2 seconds. Then the camera will pull it inside. Try it and leave a message if problem is solved.
Thank you!
