Question about Holmes Products Holmes HASF1304S-UC 12", White 3 Speed, Stand Fan With Bonus Table Base
Oscillating table fan makes banging noise when rotating
I have a Sanyo tri-speed table fan which works great. However, recently, when I tried pushed down the oscillation knob for the fan to rotate, the fan blades appear to occasionally get pulled back and bang against the inside cage. After disassembling, I found that any time you try pushing down the knob, the stem starts to retract and make a clicking sound. Sometimes it works great, but after a minute or so it starts up again. Anyone know how to fix this?
    Master:
  • 601 Answers
Another possibility could be a broken tooth on the oscillating gears that isn't meshing with the drive gear causing the knocking. If possible check the gears are all intact
Posted on Jul 22, 2014
    Genius:
  • 1,970 Answers
Mcdevito75 here, Sounds like that oscillating swtich is either a little loose or could use a drop or 2 of 3 in 1 oil. Try to twist offf the oscillating swatch button and see if you can tighten it or put a drop of oil on it.
Posted on Jul 28, 2010
SOURCE:
Table fan winding&connection daigram
  • I have a Bionaire brand table electric fan.
    • It has a 3 speed fan motor.
    • The electric motor is a BM-122 Decomin brand 3 speed motor.
      • There are 6 wires:
        • Red wire.
        • Black wire.
        • White wire.
        • Yellow wire.
        • Gray wire.
        • Blue wire.
          • The motor has a 4mu 250volt capacitor.
  • This fan has an oscillating grill with independent sync motor, and timer circuit.
  • Something was wrong with the solid state circuitry (everything worked but the motor!), but a quick test of the motor indicated it does work.
  • The motor uses a start and run capacitor.
  • I decided to change controls to a simple mechanical switch and fore go for now anything beyond 3 speeds.
  • The printed circuit board shows the following connections:
    • Black wire
    • Blue wire
    • Yellow wire
      • Are respective for the:
        • High fan motor speed
        • Medium fan motor speed
        • Low fan motor speed
  • I think the gray wire goes out to the oscillator motor.
    • The Red wire is marked as Line, for the power source.
  • All wires are in continuity with each other EXCEPT RED is not with any other wire. How to Verify Fan Motor Wiring Connections
    • Checking the Motor and Capacitor Connections
    • Double check your connections using the fan wiring diagrams.
    • You should see that there is a separate motor winding for high speed.
      • The concern is that there is a capacitor for the motor.
      • So I'm thinking that the motor may have to start with the slower speeds first.
      • and not start in the high speed because the motor or capacitor has not been designed for that type of operation.
Sep 29, 2016 | Dryers
Is Casablanca Zephyr Table fan # 1928C available???
It is. $50 on eBay.
  • Casablanca Zephair Desk Fan Table Fan Model 1928D ' eBay www.ebay.com > Search > Casablanca Zephair Desk Fan Table Fan Model 1928D Find best value and selection for your Casablanca Zephair Desk Fan Table Fan Model 1928D search ... Vintage CASABLANCA Model 1928C Floor Fan 120vac 60HZ ...
  • Casablanca Fan Zephyr Oscillating Desk - sears.com www.sears.com/search=casablanca fan zephyr oscillating desk Home / Results For: "casablanca fan zephyr oscillating desk" ... SYBA 8-inch Tall Personal Table Mini Oscillating Fan, 2-Speed, Adjustable Head, Black.
  • Casablanca Zephair Desk Fan (Table/Desk Fan) 1928D in ... www.hansenwholesale.com/ceilingfans/casablanca/model.asp?ProdNo=1928D Casablanca Zephair Desk Fan (Table/Desk Fan) Model 1928D. Choose Custom Options & Accessories Here. ... The Casablanca Zephair Desk Fan is UL Listed for ...
  • Casablanca Fans Zephair Floor Fan Portable Fan 1928F www.casablancafansonline.com > ... > Portable/Freestanding Fans Casablanca Fans Zephair Floor Fan Portable Fan ... This 0.0 light Portable Fan from the Zephair Floor Fan collection by Casablanca Fans will enhance your home with a ...
  • Mar 24, 2016 | Casablanca Fan Zephair 19N8C Table
    I have a Holmes HAS1650 stand up fan and I need to know how to get it to quit rotating.
    Not sure what you mean by "stop rotating"
    I assume you mean to stop oscillating. There should be a knob on top of the motor housing that you push down to oscillate and pull up to stop oscillating.
    If you mean to stop the blades from spinning there should be a fan speed control knob on the top of the motor housing that you turn to "O" to stop the fan.
    Here is an instruction manual for a similar fan...
    http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-holmes-products-Site/Sites-holmes-products-Library/default/v1405596036669/documents/instruction-manuals/HASF1515R_HASF1516R-UC_11EM1.pdf
    Jul 18, 2014 | Dryers
    Rattle
    Usually it's the fan or fan motor, or the rotating motor making the noise. Usually you can pull it off or clean it...AND the bearings, which could be crudded up.
    Dec 04, 2013 | Comfort Zone Cz488 Ceramic Oscillating...
    Fan will not oscillate anymore. it makes a clicking noise like it's stuck
    follow this steps and fix it. God bless you
    f the fan doesn't work at all, make sure power is on at the outlet, then test the power cord . Test the motor and replace it if it is faulty. Clean and test the speed-control switch and service it if it is faulty . If the fan works on only some speeds, clean and test the speed-control switch .
    If an oscillating fan doesn't move from side to side, check the clutch knob, then the gear assembly. If the gear assembly is faulty, you can service it (see below).
    If the fan blades turn slowly, check the blades for a loose hub and tighten if needed. If the fan shaft is noisy or dry, lubricate it.
    Nov 14, 2013 | Tower Aloha Breeze Fan
    Hi, I have an aloha 3 speed oscillating pedastal fan. motor is almost seized. can it be fixed?
    What is the estimate rotation rpm at fastest speed ? Normally pedestral fan is a 6 poles or 4 poles single phase motor?
    Jun 08, 2012 | Aloha Housewares Dryers
    How many watt it have?
      Features and Benefits:
    • Powerful 3 speed turbo fan for fast focused cooling power or enhanced air circulation
    • High performance blades rotate for maximum air velocity through the wind tunnel turbo grill
    • Pivoting head can be adjusted in a 90 degree arc for varied air distribution
    • Versatile design makes this fan great for use on desk and table tops
    • Wall mounts with separate purchase of hardware
    • Equipped with a carrying handle for transport
    • Dimensions and Weight:
    • Size: 6.33" x 11.375" x 11.125"
    • Weight: 3.5 lbs.
      Power 50W @ 110V
      Power 60W @ 220V
    Feb 14, 2011 | Honeywell HT-800 Table Fan
    Aloha Breeze Tower Fan Will Not Oscillate
    hi,
    yes this is the oscillation motor, and they generally arent servicable, and need to be replaced, you can try and oil it, sometimes they have small air vents, and you can do a voltage test with a voltmeter but I believe the motor has failed or is gummed up, you can try and take it apart, they are held together with bent metal compression areas along the circumfrence of the motor, try sewing machine oil, you might have to do some research to find a replacement motor, maybe take it to a local clock shop, those motors are very close to what they used to put in old wall clocks.
    good luck
    J
    Aug 05, 2008 | Tower Aloha Breeze Fan
    Fan makes clicking noise when oscillating
    inside the motor there is a nylon gear that is broken. the oscillation operates off a gear connected to the motor drive.
    Aug 27, 2007 | WeatherWorks CH-1850SFW Riviera Stand...
    Holmes Products Holmes HASF1304S-UC 12", White 3 Speed, Stand Fan With Bonus Table Base Logo
    989 people viewed this question
    Top Holmes Products Dryers Experts
    Jay Finke
    Jay Finke
    ray gallant
    ray gallant
    xkikbxr
    Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
