FixYa.com
Tags:
Motorola H700 Wireless Headset
Is H700 compatible with the iPhone? (by 2 users)
posted by Jamilynne on Apr 23, 2008
Can I connect my H700 with my iPhone?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by robindj1026, posted on Jul 03, 2008
How??
Best Solution
posted on Jul 04, 2008
FixYa! (100)
audiorack
Rank:Apprentice Apprentice
Rating: 99%, 15 votes
Here is a straightforward procedure to "pair" the Motorola H700 bluetooth headset with an iphone
1. Turn off the headset by folding the microphone.
2. On your iphone, go to settings-->General-->Bluetooth-->tap tp turn ON
3. To activate your headset, hold down the center button and keep it pressed while you fold out the microphone.
The iphone will immediately detect the device and state "not paiired"
Ignore this message and go ahead and tap on the headset menu displayed on th eipjone screen. You will e prompted fot a security code. Please enter 0000. The iphone will confirm that the devices have een paired successfully.
You arer done! To verify, try placing a call from the iphone and you will see a new menu on iphone asking you to choose the headset H700 or speaker phone.
Step 3 is the most important step in getting the two devices to talk.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 24, 2008
FixYa! (100)
Guest
Guest
Rating: 0%, 0 votes
yup, i just connected mine
Solution #3
posted on Jul 27, 2008
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
Thanks to whoever posted this... Great help... I was getting ready to give my H700 away..
Solution #4
Helpful (85)
jsantora
Rating: 85%, 1 votes
YES!!!!!  it worked, there are many other WRONG sequences out there.  the trick is holding the main button in WHILE opening the mike.  AND THEN, ignoring the error message and clicking on the "not Paired" message....geez...couldn't apple or motorola have spent another nickel on the hardware or software to make this more automatic.
Solution #5
posted on Sep 04, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
The real trick to getting it to pair is that when the H700 is in "discovery" mode, the light turns purple. So when you hold down the round middle button (NOT the volume buttons), and flip open the microphone, the light (that normally blinks blue) will stay solid purple.
The solid purple light indicates that the headset is now discoverable. It took me a couple of tries to get it to turn purple, but it works. Then you have to enter the PIN code on the phone (four zeros) and you should be good to go.
Solution #6
posted on Sep 03, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Wow, i had been looking for a way to connect my h700 to my iphone, i was about to give it away!!!! YOU ROCK!!!!
Solution #7
posted on Jul 30, 2008
Not Rated (0)
janettel21
Rating: 0%, 0 votes
Worked perfectly. Thanks, I finally found reliable site that helped. Thanks a bunch!!!!
Can you Help with these Headsets problems?
how to set up my bluetooth to a...
bought a headset from a friend... Answer This...
sony ericsson w580i mobile...
only half of my screen can be... Answer This...
with this H700c headset I can...
the person being called can not... Answer This...
charging problem?
My bluetooth goes red when I... Answer This...
Broke the ear hook for the...
I dropped the H500 bluetooth... Answer This...
Repair Service
Find Headset Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
