I have a wdc ser no wcapo2184087. I HAVE BACKED UP TO MY from my computer c drive 20GB to my wdc external hard drive. My backup on my external hard drive shows 1.07 GB. Is this compression normal?
  • patsal317 Apr 23, 2008
    I asked a question if backing up a 20GB harddrive and condencing it to a 1.07GB
    backup was normal? You did not answer the question.
    Genius:
  • 1,447 Answers
What's the memory capacity of your harddrive? Did you backup the entire files of your system to your hard drive or just some files?
Posted on Apr 23, 2008
  • 2 more comments
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 23, 2008
    Here you can find info how to back up files on this link
    http://support.microsoft.com/kb/309340
    or
    http://www.microsoft.com/protect/yoursel...
    and tips for backing up files
    chances are if you already reformatted your c drive then we cant retrieve them anymore.
    Here are other info before backing up files so that you wont lose important datas..
    I know the question that will run on your mind is
    Is it possible to retrieve files after a computer is reformatted?Try this site and this might be of help.
    http://www.iomegadatarecovery.com/recove...
    or
    pls dont forget to rate if helpful, thanks!!
    NO that is not normal, it should actually save backup as 20gb as well.
    Genius:
  • 1,142 Answers
No the file has not been copied or backed up propertly, can you tell me which utility have you used to backup the harddrive.
How do I view backed up files on an external hard drive?
The backup software should give you the option to restore from a backup, it really all depends on which software was used to make the backup.
May 20, 2015 | Hard Computers & Internet
Tip
Restoring your iTunes Library backup
When you need to restore your backed up iTunes Library from your external hard drive to your computer, follow these steps:
Quit iTunes.
Locate your external hard drive.
Mac: On the Desktop or Finder sidebar.
Windows: In My Computer
Drag the iTunes folder (backed up earlier) from your external hard drive to whatever location you desire on your internal hard drive. It is recommended that you choose the default location for the iTunes folder, which is:
Mac OS X: /Users/username/Music
Windows XP: \Documents and Settings\username\My Documents\My Music\
Windows Vista or Windows 7: \Users\username\My Music\
Open iTunes while holding down the Option key (Mac) or Shift key (Windows).
In the resulting dialog, click the Choose Library button.
Select the iTunes folder you just moved to the internal hard drive.
Click Choose.
on Apr 15, 2010 | Computers & Internet
Our computer died. I had backed up to Toshiba 1TB external hard drive using NTI backup now EZ. Trying to restore pics, programs etc to new computer. Getting error that says it can not find on on external...
You have an issue - if my understanding is correct ' you are trying to restore your files, programs etc., to a new computer.
Backups are meant to restore the files and windows operating system etc. on the same computer the backup was created from. If you bought a new computer, it cannot do any restoration of the backup file from the hard drive.
if this is not the case, you need to provide more information for anyone to help.
Aug 03, 2014 | Toshiba Computers & Internet
Toshina External Hard Drive backup files in
Which program did you create the backup with? You'll need to install a copy of that software on your new computer. Then you will let the software find the backup and restore it. This will only work if you used a file backup. Many backup programs do not restore to systems with different hardware (different CPU, hard drive, OS, etc.).
However, I don't know which software uses *. PFT, pfi or pfp extensions. PBF is the format for one of the older Paragon Backup software versions. Acronis uses *.TIB . For a list of many of the software extensions used for backups, see https://www.file-extensions.org/filetype/extension/name/backup-files .
Canvio drives used to include NTI BackupNow EZ software. However, I believe that NTI backups use BJF or NTI extensions. The installer for that is here: http://support.toshiba.com/sscontent?contentId=3044104 . To check for other software for your external drive, try looking up your drive at http://support.toshiba.com/support/home . The available drivers and software should be listed. Alternatively, check if the backup software installer is still on the external drive.
I hope this helps.
Mar 03, 2017 | Toshiba Canvio Plus 320 GB 2.0 Portable...
My computer had a virus and the company that repaired it for me wiped out all of my thousands of photos. I had backed everything up on my My book, but I can not find the disk or manual to reinstall it on...
Most backup programs just copy the files. In that case just plug the disk in , access it from My Computer and copy them back. If the backup program compresses them then you will need it - here it is
http://support.wdc.com/product/download.asp?groupid=110&sid=72&lang=en
Jan 23, 2011 | Western Digital My Book Essential Edition...
I backed up data w/ WD Passport External Hard Drive, and when finished my computer's free hard drive space went from 115 gigs to 11. What happened, and how can I fix this?
What could have happened is that you backed up your drive onto itself. Check your external and see if it's still empty. If you named the backup, search for that name and remove it. If not, retrace your steps right until the beginning of the backup and see what location the software stores the file then remove it.
Worst case scenario you can always use the windows restore utility and go back 1 day before you ran the backup.
Good Luck
Jul 17, 2010 | Western Digital Passport WDXML800UE...
Trying to copy backup from SimpleTecj 500 from XP to Windows 7
1. how did you back up? file by file or using a backup program?
2. does win7 see the external drive, i.e., does it show up in my computer?
Jun 07, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
How can I back up my data on my book essential?
This drive comes with Memeo / WD Anywhere Backup, so you could most like just install it on your PC and when it asks for the destination, guide it to the my book essential in my computer.
For step by step, use the link below (BTW: the product key is normall on the install guide, but most of the time, if you have your drive connected, it will detect it and auto-register without the need of a product key):
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=3530&p_created=1238718201&p_sid=_Tgc12Tj&p_accessibility=0&p_redirect=&p_srch=1&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9Mzg1LDM4NSZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9aG93IHRvIHNldHVwIHdkIGFueXdoZXJlIGJhY2t1cA!!&p_li=&p_topview=1
If you do not want to use the backup software, then copy / paste your data onto the drive.
Jan 15, 2010 | Western Digital My Book Home 320GB...
Thinks it's full
232 gbs is normal, a 250 GB hard drive has generally less space than 250 GBs, the actual size of the disk depends on the way used to format it.
Jul 27, 2008 | LaCie (300770) 250 GB Hard Drive
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
