Question about Belkin (F5D5231-4) Router
Weak connection we have wild blue internet and i just got a belkin wireless g router. before i connected my wireless laptop i plugged the ethernet cable running from the cpu tower to the back of the router and plugged the router to the modem. the internet connection was 400x slower than normal and my laptop was even slower. i figured it might be a problem with the router so i took it back and got another one of the same model and it did the same thing. what might be my problem?
  • Shuvo74 Apr 25, 2008
    I have Wildblue internet and when my computer is wired to the modem the connection is very fast.But, when I connect the same computer thru Belkin wireless N router my connection gets slow. Besides, my computer also runs slower than usual.I have connected my ISP and have done signal strength test and they reported it is good.
  • 28 Answers
HI,
As you have changed the router still the connection speed is slow, in this case it's better to contact your ISP get the line tested or a proper signal strength.
Also conduct a speedtest by going to the website internetfrog.com....indications are towards a line fault.
Posted on Apr 23, 2008
I have successfully installed a belkin surf n300 wireless router to my laptop, i can connect to the internet via ethernet cabler but when i disconnect the cable i lose the internet connection. how do i...
here is the manual http://cache-www.belkin.com/support/dl/8820ed00372_f7d2301_v1_uk.pdf
look up under your wireless security as it isnt set up right either in the router or on your computer.
look at page 8 to 13 of the PDF and follow the set up again. you will need the wire plugged in while doing this process but afterwords you can go wireless after a reboot.
Apr 30, 2011 | Belkin Surf N300 Wireless N Router
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
I have a Belkin router and i don't know hoe to cennect my laptop to my main broadband at home ,what do i do with the yelow cable do i connect the router to my laptop ? I have no clue and it;s really...
Here's how to connect the router.
From your broadban modem, connect the ethernet cable to the Internet/WAN port of the router. Then using another ethernet cable, connect your laptop to port 1 on the back of the router. Now run the setup CD that came with your router. After setting it up, it will tell you to disconnect the ethernet cable from your laptop to try the wireless function. Good Luck!
Oct 06, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
How to conect a wireless router to a regular modem
If your modem/router has a USB connectivity, you can connect it via USB. Else you will have to buy an Ethernet PCI Card, which wont cost you much.
I hope this solves your problem. Good Luck ! Kindly Accept my Solution.
Regards, Arjun
Apr 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
My laptop has vista installed via usb from virgin cable modem.what must i do to install a belkin wireless g mimo router using ethernet connection?
Huh? You installed Vista through your Virgin Cable Modem? What on earth does that mean?
Are you trying to ask "How do I install my Belkin Wireless G Router?"
If that is the actual question, here is the answer:
1) Unplug your cable modem from your computer.
2) Plug the cable modem into the router using a Ethernet Cable.
3) Plug the router into the computer using another Ethernet Cable.
4) Plug in the power supply for the cable modem and then the router.
(If your cable modem is ONLY USB, and doesn't have a spot to plug in a Ethernet Cable, you'll have to call Virgin and replace the modem with a model that does)
Once everything is up and running, you should be on the internet as soon as the computer starts.
(You may want to log into the router and disable the "Wireless" settings if you aren't using them to stop others from gaining entry to your network)
Oct 23, 2008 | Belkin Computers & Internet
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D5231-4) Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
