Question about ASUS P5PE-VM Motherboard
System restarts automatically
PC has ASUS-P5PE-VM motherboard.
It has WIN XP Pro.
System restarts automatically .
Sometime it takes 10 mins to restart..
Sometime it restarts right away at the ASUS logo screen.
Initially thought some latest oracle-jdbc drivers I installed has corrupted the system or virus attack. But since it restarts at the ASUS logo screen, I'm suspecting either the motherboard is messed up or some hardware issue..
Any tips/suggestions to find if motherboard is OK. ?
  • 1 more comment
  • Nellai Apr 25, 2008
    Thanks for your suggestions 'Danmart'
    Here's what I've tried so far.
    1] connected only mouse, usb keyboard,monitor . start PC and it goes to windows and stays there for 2 - 4 mins and restarts again. sometime it restarts even while viewing the BIOS info.
    2] I removed the firewire , extra HDD, and CD Drive suspecting too much power getting it crashed.. That didnt help.
    3] Read somewhere , this is most likely 'coz of heat. So cleaned the CPU heatsink thermal paste and re-applied it. Didnt help.
    4] Read somewhere the PSU watts(300) may not be enough. So got one from Frys electronics with (600 watts) plugged it in and tested. Didnt help.
    5] removed the battery and reset the jumper and restarted.. not working.
    One of the weird problem , I noticed was I removed all the RAM sticks and then rebooted, waiting for the beep beep beep sound. But didnt hear any.. it just starts and stays idle.. nothing on the screen. Not sure if this is related to the above problem, or some pc-speaker issue. I was just trying to see if anything can be found from the BEEP indicators for the restart..
  • Nellai May 04, 2008
    Update on the Motherboard issue.
    I talked to the ASUS tech support and took the pc to their test-center. (used their mouse/keyboard/monitor) And after running for like half hour they declared its not restarting automaticlaly and unable to reproduce the issue.
    I brought it home and plugged in again with the mouse+keyboard. And again the issue popped up. The 5 elements different from their test scenario was ( mouse, kboard, monitor, power,Air condiitoning).
    Now I took this PC to my office and ran it there with the mouse+keyboard in office and it ran fine for 3 hours and no-restarts. Suspected mouse and keyboard.
    I brought the mouse+keyboard+PC from office and plugged it in home. And the problem starts again.. (it ran for an hour 1st time , but on consequent restarts at BIOS screens).
    so mouse+keyboard doesnt seems to be the problem.
    Its most likely Power or AirConditioning.. (I dont have Airconditioning at home.)
    Meanwhile, I'll try your steps outlined to see if I something can be identified.
  • thorax363 Jun 25, 2008
    I have the same problem with my ASUS P5PE-VM, (almost). My PC restarts after a few hours or minutes, espacialy in full load( 3d max rendering, games) but it restarts even when i am using only the internet, or my tv tuner, or it restarts alt the ASUS logo. I did managed to resolve something - TIME, chek it out: in BIOS i changed the REFRESH RATE of the ram memory from AUTO to u7.8 (miliseconds). So now its not restarting a 20 times a day, it restarting 2-4 times a day, some days doesn't restart at all, but with the temperature rising in my house in summer, the proble persists; yesterday for example it restarts 8 times, I did a lot of test like yourself, with the ram module changing betwen each other, with a nother more powerful VGA card (9800pro), disconected a few optical drives, the tv tuner; i have a very good cooling system and a big tower case (CHIEFTEC moldingBX with window) with lots of fans (3X90mm and 1X120mm, my power suply is a THERMALTAKE 420W, 3 optical drves 1 is a serial ata2 DVD writer, VGA is a RADEON 9600XTGU EXTREM, tv tuner LEADTEK WINFAST 2000XP EXPERT, a paralele ata hard disk SEAGATE, 2 memory modules ELIXIR with 256 MB each, in dual channel, and the most importing think a INTEL E6300 CORE 2 DUO. witch I suspect that is not quite compatible with this motherboard, but the manufacturer ASUS say it is, i don't know, and of course i suspect the ram modules. I don't know if this helps you but I hope someone will resolve this problem, Sory if a write a bad english, I am from a medium size not important country from Europe:)
Sir i have the asus mother board i re instelled o.s xp2 pleas see the drivers download
Posted on Jun 29, 2008
I have the same problem with my ASUS P5PE-VM, (almost). My PC restarts after a few hours or minutes, espacialy in full load( 3d max rendering, games) but it restarts even when i am using only the internet, or my tv tuner, or it restarts alt the ASUS logo. I did managed to resolve something - TIME, chek it out: in BIOS i changed the REFRESH RATE of the ram memory from AUTO to u7.8 (miliseconds). So now its not restarting a 20 times a day, it restarting 2-4 times a day, NOT at the ASUS logo screen; some days doesn't restart at all, but with the temperature rising in my house in summer, the problem persists; yesterday for example it restarts 8 times, I did a lot of test like yourself, with the ram module changing between each other, with a nother more powerful VGA card (9800pro), disconected a few optical drives, the tv tuner; i have a very good cooling system and a big tower case (CHIEFTEC moldingBX with window) with lots of fans (3X90mm and 1X120mm, my power suply is a THERMALTAKE 420W, 3 optical drves, 1 is a serial ata2 DVD writer, VGA is a RADEON 9600XTGU EXTREM, tv tuner LEADTEK WINFAST 2000XP EXPERT, a paralele ata hard disk SEAGATE, 2 memory modules ELIXIR with 256 MB each at 400mhz pc3200, in dual channel, and the most importing think a INTEL E6300 CORE 2 DUO. witch I suspect that is not quite compatible with this motherboard, but the manufacturer ASUS say it is, i don't know, and of course i suspect the ram modules. I don't know if this helps you but I hope someone will resolve this problem, Sory if a write a bad english, I am from a medium size not important country from Europe:)
Posted on Jun 25, 2008
    Sergeant:
  • 291 Answers
1st) I would suggest disconnect EVERYTHING from the motherboard. Keep keyboard, mouse and of cause the monitor.turn on....wait your 10-15 minutes, play with the keyboard, flutzz with the mouse..
Nothing happens,TURN OFF cpu, add ONE other device, continue doing the same thing until something happens after a device is installed, that could be your problem. 2nd) your turning on and off the power supply could cause it to crash, then THAT is your problem.too Low or too high power supply voltages causes your cpu to reset in order to protect itself {By forcing the power supply to "crase & burn" u forced the issue.
Posted on Apr 23, 2008
  • Daniel Martinez
    Daniel Martinez Apr 26, 2008
    Disconnect everything again[all the h/d's included] turn computer on.U should see BIOS information, How meny chips connect ? How much total memory ? SWITCH memory sticks around cpu chip problems;on mother board will cause to shot down or reboot. No problems? switch the other memory in pairs of twos , if u don't see BIOS info, u found one of your problems A bad connection on the board connector. Sometimes causes win_xp to reboot.[ by the way, you know that u turn off the power when u do all this testing!?]
    2nd back up your bootable drive, FDISK, REformat h/d and REinstall windows xp AGAIN?
When i am playing windows95 road-rash game my PC automatically restarted
maybe its not compatable with your windows like xp vista win 7
Aug 24, 2012 | ASUS P5PE-VM Motherboard
Is Asus P5PE-VM series motherboard supports 2GB RAM
i have a problem with ASUS P5PE-VM motherboard, with 2 GB DDR 400 (2x1GB, Kingmax) the system (Win XP Pro or Vista) doesn't start. it hangs up in different stages.. what's wrong?
Oct 05, 2010 | ASUS P5PE-VM Motherboard
To install sound driver of P5PE-VM MODEL
Use the link provided to download Windows 7 /32 and 64bit drivers for you're Asus P5PE-VM motherboard;
http://driver-pro.com/related/english/windows-7-drivers/?a=17743&gclid=CJLvoozNs54CFYRC5god1UbDdA&hit=1&l=45
Cheers'
Mike
Jun 13, 2010 | ASUS P5PE-VM Motherboard
Multimedia audio controller driver will not install It loads the realtek driver then restarts the pc
You're P5PE-VM motherboard does use Realtek AC'97 driver. (ADI AD1888JCPZ). Preform a clean install. Download, install and run the free program ccleaner. Once installed click on the registry icon within ccleaner and run it.
http://www.filehippo.com/download_ccleaner/ Than restart you're system and enter the bios. Make sure AC'97 is to [Auto] See page 2-20 in you're manual.
Save and exit the bios. Use the Asus CD and install the sound drivers. Or download the latest drivers from Asus; http://www.asus.com/Search.aspx?SearchKey=P5PE-VM
Any questions?
Mike
Apr 11, 2010 | ASUS P5PE-VM Motherboard
P5pe-vm motherboard sound problem
buy a universal driver xp disk and reinstall the audio device
Dec 24, 2009 | ASUS P5PE-VM Motherboard
P5PE-VM Restart when software is Run
Does it only happen when you are installing software or running software on the CD drive? If so, then it sounds like your power supply will have to be replaced...as the cd drive is accessed, it drains power from the system and the computer restarts due to the drain on the power supply.
Jun 14, 2009 | ASUS P5PE-VM Motherboard
ASUS P5PE-VM Motherboard Logo
375 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
