Question about Sharp 32R-S50 32" TV
Coax connector The coax connector just broke and fell off the back of the tv. Any ideas on how to find a repair part.It looks as if it was only attached with a sliver of metal and not secured to the set base at all.
  • Anonymous Aug 19, 2008
    I have the same problem now. Its a bad design by Sharp.
  • 975 Answers
Looks like you have to replace the the tuner part (thats the slim silver box where the coax connector was ) if your handy with this solution and can repair it yourself , then you need to go to a SHARP authorized dealer to purchase the part or leave it there for repair . let me know if this helpful, thanks AJ
Posted on Apr 23, 2008
Female coax connector broke on vizio smart t.v.can i buy an adapter or reroute out of cable box to t.v.
If the cable box has an HDMI or video output, use one of them to connect to the TV instead. The female coax connector is not easily repaired and you can't reroute or adapt anything to fix it. You will need to replace the TV main board if the HDMI/video connection is not an option.
May 05, 2017 | Vizio Televison & Video
Cable end broke on tv
You will need to open up the tv and re-solder the F connector back on the board it fell off of.
Mar 16, 2014 | Proscan Televison & Video
The coax cable nipple (labeled "RF") on the back
As long as it was a clean break this will be an easy fix. If the tuner got damaged at all, then you will need to replace the whole tuner, which can be a bear if it is a two sided board. You can buy a new connector at just about any electronics store. You will need a soldering iron, solder and wick for the repair. You might be able to just solder the original connector back on if the break is clean enough. You will also need to stick a wire or something like that in the hole to keep the plastic from melting shut from the heat of the iron.
Apr 11, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
The attachment point for the coax cable was pulled off-broken off
You'll need to take it to a repair shop. There are high voltage capacitors inside a television which will hold a charge even after all power is removed. I would highly advise against making this repair yourself.
Dec 03, 2009 | Sharp 27H-S60 TV
Digital to analog converter box hookup
You will have to go to Radio Shack or Wall Mart, maybe Home Depot and get a matching transformer. That will have spade terminals on one end to connect to your tv and a round (75ohm male thread) to hook to your converter box.
Jan 08, 2009 | Televison & Video
Cable/antenna connector
you can try to get just the coax replacement , otherwise you will have to get the whole tuner, and the number for the tuner is right on the tuner , but just soldering in a new coax connector is cheaper
good luck and thanks!
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
Tv coax f connecter is broke off cannot hook cable cord on it. or antenna
I looked up the manual for this TV and it has composite (RED, WHITE, YELLOW) and component (RED, GREEN, BLUE) connectors as well.
Are you using a cable or Dish box? If so, those boxes usually have output in Coax, Composite, and Component formats. You could just run that type of cable. If you use Component you will also need another cable set (RED, WHITE) for audio.
If, on the other hand, you do not have a cable box and you are using your TV's tuner you only have two options. You can repair the broken connector or you can route the Coax through an inexpensive VCR which will allow you to convert it to Composite cables. In this case, however, you'll have to use the tuner in the VCR, not the tuner in the TV to change the channel. Sorry it's not the best of news.
I want you to know that I'm not paid for this. It's a strange hobby I know, but I like to help when I can. While I cannot physically repair you TV, I hope you've found this information at least helpful and will rate it positively. If you have more questions please don't hesitate to ask. Thanks, and good luck.
Jan 03, 2008 | Vizio GV42L 42 in. LCD Television
Sharp 36R-S450 Coax broke off Help!!
it should be alot to fix all u have to do is buy the coax connector n solder it
Oct 28, 2007 | Sharp 36R-S450 36" TV
Sharp 32R-S50 32" TV Logo
201 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
